What do i need to run breathers!!!!!!
Old Mar 9, 2006 | 12:17 PM
n20stroker's Avatar
Default What do i need to run breathers!!!!!!
I want to get rid of my pcv system and run some sort of breather setup.
what do i need and who sells it.
thanks
Old Mar 9, 2006 | 12:23 PM
GuitsBoy's Avatar
thanks
I went to autozone, and bought:
(2) 5/16 vacuum caps - $2
(2) 5/8 push in breathers - $12
(1) LS1 Oil Cap. - $6
Drill a 5/8 or 3/4 hole in the oil cap and silicone the breater to the top of it. Push the other breather into the drivers side grommet in the back of the valve cover. Cap the intake and rearward pass side valve cover nipples. Leave the air tube from the throttle body to the forward pass side valve cover nipple.
THE END
Old Mar 9, 2006 | 12:25 PM
strokedls1's Avatar
The metco breather goes where your oil cap is. I just did two small k&n filters on either valve cover. The metco one can be bought from thunder or speed inc. I bought the k&n filters at a local speed shop for 15 dollars. You can then disconnect the rest of the pcv system.
Old Mar 9, 2006 | 12:31 PM
777's Avatar
777
THE END
What's the reason for leaving the air tube from the throttle body to the forward pass side valve cover nipple?
Old Mar 9, 2006 | 02:55 PM
Disturbed Bird's Avatar
what do breathers do
Old Mar 9, 2006 | 02:56 PM
777's Avatar
777
They are mini filters that let air pass through just like an air filter. In this scenario they are letting the positive crank case pressure vent without letting dirt and stuff into the engine from the outside air.
Old Mar 9, 2006 | 05:00 PM
n20stroker's Avatar
thanks guys, while at the track i have oil pushing out the valve and getting on my intake. Also how do i stop the oil from getting in my tb.
Old Mar 9, 2006 | 05:53 PM
777's Avatar
777
If you ditch the pcv system oil won't go anywhere in the intake track. Therefore, no oil on the TB.
Old Mar 9, 2006 | 08:44 PM
GuitsBoy's Avatar
Theres a check valve in the valve cover... in the unlikely event you have a vacuum it pulls in fresh air.
Old Mar 9, 2006 | 11:53 PM
n20stroker's Avatar
do u guys have any pics of your breather set up? I bought 2 breathers 1 1/4 will they work?
Old Mar 10, 2006 | 07:58 AM
GuitsBoy's Avatar
Probably not. I bought one thinking it might thread in as an oil cap replacement, but its a different attachment. That why i drilled through the oil cap. The 5/8 stem breathers are a good fit for a drilled oil cap as well as the driver side grommet, although it wont fit all teh way down because of the coil bracket.
