These lifters look decent?
Lunati 72432
Anyone have any experience with these? They look like a good lifter and measure approx. 2-15/16" in length...but the stock lifters measure 2-5/8" in length...will there be any problems with this? Let me know your thoughts.
![](http://www.midwestfbodymeet.com/pics/lifters.jpg)
Dont mean to sound like a dick, but that didnt even come close to answer my question. I already own these lifters...just want to know if anyone has had any experience with them and/or if they look like a decent design. Plus, I want some decent lifters cuz this is what happened to my stock "GM" lifters...
![](http://www.midwestfbodymeet.com/pics/DSC00385.jpg)
Looks like you got another Futral Motorsports (CAM MOTION) defective cam. Those stockers should have been fine with that cam.
As far as the Lifters go, you got your self a gold mine. Those Lunati Lifters are actually the Morel Lifters. Morel supplied Lunati with those lifters a couple years ago. So, expect only the best.
best Regards,
Adrian
best Regards,
Adrian
best Regards,
Adrian
best Regards,
Adrian
So if they are a Morel equvilent, then why dont more people have them?
ok also...the stock lifters measure 2-5/8" in length whereas the new ones measure 2-15/16"...will there be any problems with this? Will I need way shorted pushrods? I am confused about this...but thats awesome that they are Morels!
Originally Posted by OneMeanZ
That's cool as hell that they are Morels, I would assume you'd need a shorter pushrod. What size pushrod you running now?
What do others think about this? Any other Morel users?
Good thing is that I got these lifters for like $380 shipped
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by GuitsBoy
Also the morels like around .030 preload from what I hear, whereas the OEM and other manufatures like anywhere from .050 to .120
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Best way to check is to use the PR length checker. Just make sure that the lifter is on the base circle of the cam lobe, throw the pr checker in there torque down your rocker, then open the checker until you hit ZERO lash. Zero lash is when it JUST hits the bottom of the rocker base, with no pressure. Then, just add .030 to your measured length. I ended up having to run 7.275 in pushrods on unmilled LS6 style heads with MLS gaskets. That left me with .025 preload, because 7.28 would have gotten me .030, but I couldn't get any.
Best of Luck!
Adrian
Best of Luck!
Adrian
Lunati gave you the correct numbers. Chris told me the lifter body is longer, but the length from roller tip to lifter cup is the same as stock. Still, since your preload must change and the range is much tighter to control, you will need new pushrods. I have Crane adjustable rockers, so my installation will be a little easier with regards to controlling the lifter preload setting.
My Morel's came in the other day
Good luck with your installation, let us know how you make out with the lifters.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Good luck with your installation, let us know how you make out with the lifters.![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Lunati 72432
Where did you get the lifters from? I checked a few sponsors and couldn't find anything.
