making horsepower on LS1
Old Mar 12, 2006 | 06:47 PM
cowboysfan's Avatar
Default making horsepower on LS1
I have heard that there is power to be made by shimming rocker arms, can some one explain on this or tell me where to find info on how to do this.
I just installed heads/cam. Comp Cam 231/237 .589/.595 112 lsa,patriot heads ls6 59cc. chrome molly p-rods, 850 Comp Cam lifters. I get that sewing machine sound and have noticed by pushing down or pulling up there is some play. will shimming help this or should I get longer p-rods? either way I go, how do I measure for shims or correct length p-rods? any help on this ,I would appreciate. thanks
cowboysfan
Old Mar 12, 2006 | 06:59 PM
BLUE99T/A's Avatar
Shims are gonna change the contact point of the rocker to the valve. Pushrods length is probably what you're gonna be concerned with. JRP's FAQ page has a p/r calc link on it.
I gotta do the same with mine. I'm about to order a p/r checker.
Old Mar 12, 2006 | 11:46 PM
cowboysfan's Avatar
so if I shim my rockers, I'll have to check p/r length? who/what is JRP ?
fuerzaws6
formerly (cowboysfan)
Old Mar 13, 2006 | 12:02 AM
ThirdGenLS1's Avatar
fuerzaws6
The JRP cam guide is what he is refering to, its a stick at the top of the internal engine section. https://ls1tech.com/forums/generation-iii-internal-engine/327734-cam-guide.html
Old Mar 13, 2006 | 07:53 AM
GuitsBoy's Avatar
Sounds to me that the idea here is that by shimming the pedestal, the rocker hits the valvestem closer to the tip, effectively increasing the rocker ratio. For the 1 or 2 HP i could see this making, it dosnt seem to be worth having incorrect geometry and inproper lifter preload.
Old Mar 13, 2006 | 09:32 AM
sho-me speed's Avatar
Closed ex-Sponsor Account
I had the same problem a week ago when I installed my cam. I changed to 7.425 PR's and now it is much quieter.
Old Mar 13, 2006 | 09:42 AM
PREDATOR-Z's Avatar
Longer p-rod is your answer
7.425's will help a lot
Old Mar 13, 2006 | 10:55 AM
cowboysfan's Avatar
cool thanks. I did the geometry align. check. did look centered but, .025 is hard to see.
greatwhitess- what lifters are u currently using?
I'll order some p-rods (7.425) soon.
thanks guys.
fuerzaws6
