Any 400 rwhp 228/228 cars?
I was thinking of getting this cam installed in my c5 corvette A4. i have long tubes,CAI,exhaust, and 3000 stall. Im also debating if i should get it on a 112lsa or 114lsa. Im looking to get close to 400 rwhp with a good tune. What do you guys think.
![Post](https://ls1tech.com/forums/images/icons/icon1.gif)
Great cam! I have a 228/228 .588/.588 comp XER 114 LSA +4...Love it. The car made 410rwhp cam only through the exhaust and I just installed PRC LS6 heads same cam. 432rwhp 400rwtq untuned...I expect to make 445 to 450 tuned through the ls6 intake.
you won't get anything near 400 rwhp with a 228 cam in an ls1 a4 vette.
you have the automatic and irs working against your dyno numbers.
i don't know of many cams that will put an ls1 a4 into the 400 rwhp cam only. i think the t-rex and g5x4 are the only ones close, and more often than not...won't do that in a cam-only car.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
I would go with that cam but im worried about not having the lowend, and i still have the 2:73 gears that i won't have the funds to replace untill the end of summer. also thunder racing has the cam pkg with everyrything you need for around $700.
even if i have all the boltons and a good tune? I see lots of A4 Camaro and T/A guys having 400 rwhp and have cams alot samller then G5x3 or Ms3 etc.... ![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Im not looking to break any dyno records or anything like that, i just wanted some opinions on what you guys thought. thanks for all the input guys. what i'm mainly looking for is a car thats a daily driver that can hold it's own. if it takes some pp heads than i guess ill have to go that route.
Not quite the same but I have a 226/226 setup that makes 414/396. This is on a Z06 though, so LS6 heads and LS6 intake, stock TB, UD pulley, longtubes, x-pipe, tune, heavy motorsport Z06 wheels.
Hope this helps a little anyway....
but you won't see 400 rwhp with that cam alone in your stockish c5...
with heads, yes you'd definitely be close. i also think you'd be close with a 90/90 setup...
intake+tb vs heads? i think heads are cheaper and would give you better gains from idle to redline..over the intake. (dayum those 90/90 setups are salty)
Going to be hard without heads and having an A4. Before my ported TB and Cut out I made 388/375. I bet I am pretty close to 400, but wish I had some heads now. You may not hit 400, but it will be fast and still drive pretty decent.
Originally Posted by yak
well fbodies have a solid axel vs the vette with IRS that is why vettes dyno lower, I still think you should go with the f 13 on a 114.
