Cam Storage
Old Mar 19, 2006 | 09:00 PM
indygoat's Avatar
Default Cam Storage
I have an LG X2 Cam that I wont be installing for awhile. Im keeping the cam inside, but any recommendations for storage of the cam as far as lubrication, etc ... ?
Old Mar 19, 2006 | 09:03 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Put it in a sealed bag with some motor oil or WD40 or something. I don't know if it matters if you store it upright (standing up) or laying on it's side though. I would stand it up on end.
Old Mar 19, 2006 | 09:10 PM
s346k's Avatar
stand it on end.
same principal as storing a crank. if stored long enough laterally it will, in essence, make a banana out of it.
Old Mar 19, 2006 | 09:11 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I figured as much.
Old Mar 19, 2006 | 09:12 PM
indygoat's Avatar
Ok, thanks guys ... Im going to go degrease it and clean it, then Im going to lube it up with some 5W-30 put it in a big trash bag then back in the box it came in and stand it up.
Old Mar 19, 2006 | 09:41 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I did the same thing. good luck in the future when you slam that stick in your motor!
Old Mar 19, 2006 | 09:50 PM
indygoat's Avatar
Im looking forward to it, it will definitely be this Spring at some point ... but it had already sat for a few months, so I figured I should probably get it cleaned up. It's a pretty mean cam, I've been told.
Old Mar 19, 2006 | 09:58 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
G5X2...yes you will like it.
