stinkin' cometics
Old Mar 25, 2006 | 06:21 PM
Fireball's Avatar
Default stinkin' cometics
got the motor done today...fired it up...ran good...until...
I find milky oil
F'in cometic gaskets leaked
Ripped it back apart. found nothing unusual, but I'm spraying with the copper sealant and retorquing the studs down again
The ETP headed motor does sound healthy though
something should've told me it wasn't right when I added the coolant and it self-bled itself. normally you have to blow on the rad opening until it comes out the top hose...it came right out immediately...
Old Mar 25, 2006 | 06:24 PM
cantdrv65's Avatar
Post
Thats exactly why I went with the stock GM MLS....Good luck man cant wait to hear some results! How much torque on the studs? Just curious....
Old Mar 25, 2006 | 06:34 PM
Fireball's Avatar
I was trying to get my quench down some thats why I went cometic. If it leaks again...GM MLS for sure
Probably not enough. I was told by a local shop to try 65 ft-lb. Thats what I had. 75 this time around
Old Mar 25, 2006 | 06:43 PM
cantdrv65's Avatar
Post
I went 80 on mine. Of course that was using motor oil....
Old Mar 25, 2006 | 06:49 PM
joshp14's Avatar
I bought Cometics for my head setup...I hope that I dont have that problem. Does Cometic recommend going on dry or with a copper spray?
Old Mar 25, 2006 | 07:54 PM
Fireball's Avatar
need alot with oil. I used ARP moly lube.
Old Mar 25, 2006 | 08:56 PM
mr2guru's Avatar
That is why I went with SCE ICS titans to get the .043 I was looking for. I've heard way too many horror stories with cometics... and that besides the issues I've had in the past with them and other cars. I don't know if they are finicky or what. But I'm not using them again with other options.
Old Mar 26, 2006 | 04:18 AM
cantdrv65's Avatar
Post
exactly....Its bad enough having to do something like a head install twice due to your own boneheaded mistake, but it would REALLY **** me off if i had to do it again because of a part issue....
Old Mar 26, 2006 | 10:30 AM
StreetStalkerZ's Avatar
I have heard nothing good about the cometic gaskets as far as sealing up. I went with some MLS GM gaskets with my new setup for that reason,last thing i need is to yank the heads again because of a leaking head gasket that could have been avoid all together the first time around.
Fireball,whats the new combo your running?
I'm hopeing to run mid to low 10s NA with mine but it will be a tough challenge with a 347ci motor.
Old Mar 26, 2006 | 11:25 AM
Fireball's Avatar
looks like I'm good now. pulled it apart, cleaned it up, and copper coated the gaskets. Torqued them bitches down to 75 ft-lb
Looks like its holding coolant pressure now. The rental tool I got sorta sucks and has a very tiny leak at the cap, but it was losing pressure very very slowly. heard nothing coming from the motor either leak wise @ 15 psi pressure.
Old Mar 26, 2006 | 11:26 AM
Fireball's Avatar
ET 225 heads, somebody's camshaft and a victor jr single plane setup.
Gunnin' for single digits
