98 oil pump Question
Old Mar 26, 2006 | 04:51 PM
KurtRardin's Avatar
Veteran: Marine Corps
Default 98 oil pump Question
I've noticed that when my car warms up the oil pressure needle wont stay still at idle. Its reading under 40psi, which is normal, but it just has a slow jump to it like its fluctuating a few pounds up and down. The slightest bit of throttle stops it. I use Mobil1 5w30, and about a half quart of Lucas.
I was just wondering if this was the "sign" that the 97-98 oil pump was about to crash and burn. 75000 miles.
Old Mar 26, 2006 | 05:17 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well, an Ls6 might do you some good on a higher mile motor. You plan on doing a cam in the future? That is optimal time to change that thing out.
Old Mar 26, 2006 | 08:07 PM
KurtRardin's Avatar
Oh yeah, i've been wanting to do a Torquer V2 for a long time, but i just cant scrape up $1000 for everything i need to do the swap.
Old Mar 26, 2006 | 08:25 PM
indyboom's Avatar
Some cars just do that. i bet your ok. If it was gonna dump then it would of gotten worse. Im sure that mine does too. I dont stare at the fine line.. Its electronic and any impulse can make that happen/.. I think gmpartsdirect has those pumps CHEAP...
Old Mar 26, 2006 | 08:29 PM
ashade98's Avatar
My needle seems to jump around a bit too, once it's warm (on a 98). I switched to a ported LS6 during my H/C swap. Still does it. It could be the sending unit. Don't worry about, if it bugs ya too much get a mechanical guage to make sure it's accurate!
Old Mar 26, 2006 | 08:30 PM
Z28LS1camaroguy's Avatar
yeah its prolly the Oil Pressure Sending unit being a piece of plastic ****. mine does the same thing but changed over to a LS6 Oil pump and still does it but got better pressure than i use to have.
Old Mar 26, 2006 | 08:58 PM
ROCNDAV's Avatar
1998's gauges were directly connected to the sensor (analog input), weren't they? I think in 1999 the signal then went to the ECU which then sends out a digital signal to the gauges. Maybe you're just seeing analog variations from the sensor either due to voltage fluctuations or just plain engine speed.
If none of this makes sense, I promise never to come back on this forum after having a couple of beers
Old Mar 26, 2006 | 09:47 PM
KurtRardin's Avatar
Thanks for the info. I didnt feel like it was serious, but i thought i better be safe then sorry and just ask. The great thing about our cars is that there are so many of them that i doubt you can be the only guy with a certain problem.
Old Mar 26, 2006 | 11:24 PM
gnomee's Avatar
I have a 98. I have noticed that the filter makes alot of difference in how the oil pressure works. At idle on a cold start with my a/c delco filter and 10w30 mobil I sit right at 40 no pulsing or anything. Once it gets warmed up ith sits between the 40 and 20 line on the left. With a fram and other crap it sits right on the 20 once its warm and never breaks 40 until I hit 2000rpm. No additives in mine either.
