Pushrod length?.... n o t the usual question though.
Old Mar 29, 2006 | 06:50 PM
99ssleeper's Avatar
Default Pushrod length?.... n o t the usual question though.
The base circle on my cam is 1.450" compared to the stock measurement of 1.550". This is a difference of .050" on the radius, so one would choose 7.450" pushrods to retain the current lifter preload. But, to help combat lifter pump up, should I run the preload a little looser and go with 7.425" pushrods?
If anything, the engine is quiet now so with 7.450" pushrods it should be the same. It would probably increase the preload by .005" over what it is now. I dont want to get technical with the actual stock pushrod measurement of 7.395 and stuff.....005" is not a big deal.....025" is a big deal.
So, which would you choose and why? 7.425" or 7.450"?
I am leaning towards 7.425 as a happy median.
Old Mar 29, 2006 | 07:15 PM
theinstag8r's Avatar
pushrod calculator
Stock base circle - New base circle = XX
1.55 - 1.45 = 0.10
> 0.10 / 2 = .050
my stock pushrods were 7.375. yours should be the same. so you really need 7.425 BUT. i ran 7.4's in my car and my dads and both of them run perfect. contrary to what people say we have absolutely no valvetrain noise. sounds like stock and should be a little easier on the lifters
Old Mar 29, 2006 | 08:10 PM
black_z's Avatar
"searches for a cam with base circle 1.450" Mike, hop on AIM.....
Old Mar 29, 2006 | 11:04 PM
99ssleeper's Avatar
lol....black z is freakin columbo.
hahaha...
Old Mar 30, 2006 | 12:55 AM
PREDATOR-Z's Avatar
I use 7.425's on 1.45x base circles
To void any arguments, measure your preload. It shouldn't be lower than .060 on OEM lifters.
Old Mar 30, 2006 | 02:37 PM
lowchevy2go's Avatar
how can you measure pre-load?
Old Mar 30, 2006 | 02:44 PM
PREDATOR-Z's Avatar
2 methods:
>Super accurate is to use a dial indicator
>and the old school (mark the p-rod) method
Old Mar 30, 2006 | 03:17 PM
Hodge's Avatar
Put in new cam and measure it's preload then decide what preload you want to run and buy pushrods based off that decision.
I just installed a cam (ZLP #51013) with a base circle of 1.479". Lifter preload with this cam was around 0.130". Decided I wanted 0.080" preload. Bought 7.350" pushrods (0.050" shorter than stock). Put then in last night and preload was about 0.080". Exactly what I wanted.
Old Apr 22, 2006 | 02:29 PM
98 Raptor TA's Avatar
where can i find a how to on checking preload with a dial indicator? i wanna check my preload but i've never done it before so i'm not sure what kind of dial indicator to buy and how to go about checking it correctly. It's probably easy to do, i've just never done it so a how to would help out. Unless one of you guys can just desribe to me how to do it.
