IMPORTANT: is there an oil restrictor, "barbell restrictor" or any INTERNAL oil plug?
I can't tell if y'all just got trolled or not... but I think y'all just got trolled.
The following users liked this post:
Blac94z28 (05-25-2020)
It was so obvious that I thought everyone was joking with their replies. Lol.
NSFW (09-01-2019)
It's not a restrictor. It sends oil from the pump into the oil filter boss and also seals the galley so oil doesn't gush into the rear cover.
Why it's needed:
Attachment 607157
The "barbell":
Attachment 607158
Where it goes in the rear of the block:
Attachment 607159
Front galley seal:
Attachment 607160
Why it's needed:
Attachment 607157
The "barbell":
Attachment 607158
Attachment 607159
Front galley seal:
Attachment 607160
LS1Tech Sponsor
If you are installing a Barbell/Oil Diverter, our precision fit Billet Barbell is the way to go. It forces the oil through the filter and keeps unfiltered oil out of the bearings and lifter needle bearings.
Here is more info and videos on how it works.
https://www.saccitycorvette.com/OilS...provement.html
![](https://i1119.photobucket.com/albums/k623/saccitycorvette/Oil%20Improvemnt%204%20pcs3_zpswxuetx2l.jpg)
__________________
Don't forget to check out our products at www.saccitycorvette.com
![](https://ls1tech.com/forums/signaturepics/sigpic197936_1.gif)
If you like our products, tell others! If not, tell us!
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
