What happened??
Old Apr 4, 2006 | 02:45 PM
92zcamaroperson's Avatar
Default What happened??
I tightened down the mains to plastiguage everything and when I pull them out this is what it looked like.
All of the bearings are like this on the same side except for #5.
Old Apr 4, 2006 | 09:05 PM
ttt...
Old Apr 4, 2006 | 10:02 PM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
The main caps on right? 1-4 main cap markings go on the drivers side, and #5 is on the passenger side.
Old Apr 4, 2006 | 11:22 PM
All were facing the right direction. Standard size clevite bearings. Followed the correct torque pattern. I dont know why it did this...
Old Apr 5, 2006 | 01:48 PM
ttt.....is this normal? I was under the impression that any scratches on the bearings was bad and called for replacement.
Old Apr 19, 2006 | 10:21 PM
Ok......heh....yeah....Joseph thank you sir you have humbled me....I put 4 of the main caps facing the wrong way. Didnt read your post right at first. So most likely this is my problem....backward main caps....i should start drinking....I even took pictures before dissassembly so I wouldnt screw up....then I did...
Old Apr 19, 2006 | 10:23 PM
But one question. My haynes manual talks about an .0008 oversize bearing for the rear main only on some motors...Anyone know if this would apply to a 2000 block? It could be refering to LT1 motors but im not sure.
and since the caps were backwards that would throw the plastigage off right?
Old Apr 19, 2006 | 10:53 PM
-Joseph-'s Avatar
I've heard of putting oversized bearings in GenI SBC motors for line bore problems, but not in a LS1 at least not for the same concern. Sometimes we've had to put oversize bearings in LS1's if the clearances are too loose, it tends to be a bearing mfg issue, not something worn out.
I would prob re-platigage it with the main caps on right. Glad thats what it ended up being, its all I could think of.
Old Apr 20, 2006 | 12:45 AM
Must be for one of the other motors then. Thanks again. I can't believe I did what I did. TWICE!
Old Apr 20, 2006 | 02:08 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You need
