TR224 idle
Old Apr 6, 2006 | 10:52 PM
garrettpen's Avatar
Default TR224 idle
Just curious has anybody with a TR224 had to drill the hole in the throttle body, or did you just fix the idle completly with tuning?
Old Apr 7, 2006 | 08:17 AM
oange ss's Avatar
open TB blade with set screw first, but dont go over .60 TPS voltage....
Old Apr 7, 2006 | 08:22 AM
ashade98's Avatar
I have the 224 in the sig, and my car idles pretty damn good on stock tune! Very drivable anyway.
Old Apr 7, 2006 | 08:55 AM
radkon's Avatar
You can get it right with a tune. If you have a crappy tuner you can use the TB set screw to let a little air in without drilling the TB blade. I would drill only as a last resort.
Old Apr 7, 2006 | 08:57 AM
Predator's Avatar
Exactly, "last resort." I ended up filling the hole with Liquid Weld and redrilling the stock size hole, after a good tune.
Old Apr 7, 2006 | 10:41 AM
Ryan02SS's Avatar
Like mentioned before only drill as a last resort. Back in the old days lol it was a easy way to make an LS1 idle better with a larger cam. With tuning capability now it hardly ever needs done.
Old Apr 7, 2006 | 01:35 PM
SPRAYED 01's Avatar
Mine ran great with no tune,it would surge when you let off the gas but other than that it was fine. got it tuned and it drives almost like stock.397hp stock heads through 9inch.
Old Apr 7, 2006 | 04:57 PM
davered00ss's Avatar
Moderator
I had no ideling issues before the tune. After the tune the car is great.
Old Apr 7, 2006 | 05:09 PM
MiaSSmaro98's Avatar
hey guys what power gains over the stock cam will i see with tsp224r?on a 112 lsa.i want choppy.
Old Apr 7, 2006 | 05:55 PM
Redneck Z's Avatar
I believe TSP says 30-35rwhp.
Old Apr 7, 2006 | 06:01 PM
i know thats wat they state but i will like to know from the members running them
Old Apr 7, 2006 | 06:09 PM
Redneck Z's Avatar
Those #'s are pretty accurate.
Old Apr 7, 2006 | 06:36 PM
Moderator
I gained 33rwhp & 14rwtq.
Old Apr 7, 2006 | 10:37 PM
garrettpen's Avatar
Thats interesting you guys said it will idle fine on a stock tune. Mine is basically stock, deleted rear O2's, air, EGR, removed tourqe managment. Mine will die if i let it go under 1000RPM.
Old Apr 8, 2006 | 07:21 PM
dave only14 rwtq that sucks?
Old Apr 8, 2006 | 07:27 PM
daryl2cb@yahoo.com's Avatar
Mine usually dies if the car is not 100% warm, and if I back up and cut the wheel with the car in reverse, I got a speed inc tune, so I have yet to drill or turn the throttle plate open yet. I guess even with a good tune you still could have an issue.
Old Apr 8, 2006 | 07:34 PM
jdaniels's Avatar
It's not THAT choppy. It's a nice, strong cam however. I am happy with mine.
Old Apr 8, 2006 | 07:35 PM
jdaniels's Avatar
Oh, and I thought I had posted this already... but even a good tune can only do so much for your idle. In order to retain the proper IAC range, you must drill. Even Ken@HPtuners will tell you that.
Old Apr 8, 2006 | 08:33 PM
headsupkid01's Avatar
I never heard of drilling a hole in the tb to adjust idle, i had mine bumped up to 850 during the tune and have had no problams.
Old Apr 8, 2006 | 09:20 PM
Black04A4's Avatar
I just had a dyno tune done at RWTD my IAC's are way out, James says the only way to get them back down is to drill.
