Just picked up a 02 Z and now it's making noise
Well just picked it up on Monday. The next day I hear a tapping from the motor. It was on my driveway on an up slop. I changed the oil and it was still there and load. It don't sound like a rod knock it sounds like it's coming from the lifters. I started driving it and it went away. I parked it back on the drive way and it started doing it again. I backed it in the drive way same thing. drive the on the street and it goes away. WTF?? It has to be an oiling thing. I'm just looking to see if anyone else has had this problem. It's still under a warrantie. So I may just change the lifters to see if thats it. Any input will be helpful.
Thanks...
Thanks...
Oil pressure, see what the gauge reads at idle and under driving conditions, if it's low at idle and higher during a drive, that's one main thing that will cause noise to come and go.
Originally Posted by JakeFusion
LSx's are loud engines anyway. But, yeah, sounds like an oiling issue on the lifters, because it happens on an incline at idle.
Sounds like piston slap, I could be wrong because I've never encountered any, but if it is then it's nothing to worry about. It's just kinda annoying while the engine is warming up. The slap goes away when the engine is at running temp though.
Bomber Z: whats up? I also tread on the Sffba.net forum, not much since I had to move to AZ for the military. Known Booty and Adam(Magnus) for quite a few years.
It sounds like piston slap. However, try letting the car sit on level ground overnight and start it. If the noise is not there or as great, then you 'might' have an issue with oil pressure and lifters taking a bit to pump up.
Ski
Ski
