Cam suggestions for my car.
Old Apr 12, 2006 | 03:56 PM
will82's Avatar
From: Somewhere Between Mild Insanity and Complete Psychosis
Default Cam suggestions for my car.
2002 Corvette
-A4 Tranny
-2.73 gears
-B&B Short Tube Headers & Bullet Exhaust
-Intake
I don't want the car shutting off at red lights.
I don't want to EVER get rid of the 2.73 gears.
I don't want my engines idle speed to be any higher than around 900 rpm.
I don't want to have to constantly maintain the valvetrain.
I plan on FI one day, and would like at least a little more exhaust duration than intake.
Car is street driven, not tracked.
I don't care how loud it is.
I would probably also add some low cost heads, like the $900 ls6 heads that TSP has on their website.
Please give me some cam suggestions, as well as reasons why you recomend the particular cam. Thanks!
Old Apr 12, 2006 | 03:59 PM
stevemilz's Avatar
Thunder Racing Custom "CheaTR" Camshaft - 214/230 .601/.578 117 LSA. Off Idle-6800 RPM Power Band. Broad power range. Works well with stock exhaust manifolds and catalytic converters. Stock like idle. Minor tuning required on automatic transmission cars. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended. Double valve springs and titanium retainers required for this cam.
Old Apr 12, 2006 | 04:06 PM
LS1SpeedAddict's Avatar
Ditch the 2.73s for some 3.23s and get a 224 cam.
Old Apr 12, 2006 | 04:21 PM
00cls1camaross's Avatar
how about those MTI stealth camshafts? anyone have any graphs or know how they compare to the cheatr?
Old Apr 12, 2006 | 04:31 PM
Black04A4's Avatar
Take a look at the cam in my sig, it idles well with the stock converter and pulls hard up to 6500.
The reason I picked this cam was because of the mild profile, less wear and tear on the rest of the valvetrain.
Old Apr 12, 2006 | 04:54 PM
will82's Avatar
This is actually one of the cams I've thought about. I was also considering the one below it from Comp (212/218) and the one above it (218/224).
What rpm does your car idle at?
Old Apr 12, 2006 | 05:01 PM
will82's Avatar
Any more suggestions?
Old Apr 13, 2006 | 06:18 AM
will82's Avatar
ttt ??
Old Apr 13, 2006 | 07:12 AM
GuitsBoy's Avatar
I think you should go for a baby cam. Youre on the right track looking at 214 - 220 cams. That should keep drivability where you want it.
Old Apr 13, 2006 | 08:27 AM
1slowls1's Avatar
get the gm hot cam 218/227 .525/.525 112 nothing to crazy.
