TSP Torquer 2 in A4 car - OR MS3 - opinions???
Originally Posted by Relativelyfast
We are looking for some big peak numbers too though.
I know people say peak but look at a ms3 dyno sheet. Once you get up there in the RPMS, in a manual car, every shift your making BIG power.
if your shifting at 6500rpm give or take you drop what 1500rpm so a big cam so will pull a little one with a 4,000 stall . Also that type of power isnt being made at part throttle only when WOT .
I have a big flattappet compcam XE in a s10 with a 355ci and NO STALL, but 4.10 gears /th350 I LOPED away from carS from a light easy , had some integra going through his gears from a stoplight and i just 1/2 throttled my factory 1800stall away from him granted its not the best combo but it still will light the tires at will and im probly only 300rwhp
A V8 with a large cam will have more than enough of drivability torque them either downshift or flash your 4000 stall and
I'm thinking I will lose some lowend as opposed to stock with an MS3, but I can't floor it off of idle on the street as is, so it won't hurt me at all. Then I should make big power once it starts winding out.
LS1 Tech Administrator
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by Patrick G
That might be true in 1st gear, but if you try racing me from a low rpm roll in 3rd gear, I would show you my tailights so quick it would make your head spin. Area under the curve is where it's at, not just peak.
the torque is right instant boom hook I'm gone riding the horspower 6500rpm shift 2nd gear tires hit violent {torques right their } by now the big cams walking you so you
BIG CAMS ARNT MADE FOR NUTHIN
Originally Posted by cws T/A
go the 4000stall hits (hell ill go 5000rpm stall some run **** like that on here )
#32
I was tring to make a point . High stalling A4/ A3/A2 do not load the engine as bad as a T56 unlocked . Hence area under the curve the manual guys chime in and **** with auto guys camshaft selection
If a t56 car was at 3000rpm in 3rd gear and raced a 4000+stalled auto at the same mile per hour with the same camshafts ,mods which would win by 100mph
#33
Now if you're running a Pro Thruster 4600, then the cam recommendations change completely. But with a tight 3200 stall, more mid-range torque is going to get the car down the track quicker than putting in a top-end biased cam.
#34
Why would anyone run from a 3rd gear LOW rpm roll?
Any type of roll with anyone your around 4krpms at MINIMUM. The ms3 car would show your its tailights no?
From a dig also.
right or wrong?
#36
From a dig also.
right or wrong?
From a dig also.
right or wrong?
Same thing goes with cylinder heads. The high flow number at .650" lift might sell heads, but the flow at .350-.500" is what normally matters the most.
#37
From a dig also.
right or wrong?
From a dig also.
right or wrong?
If you got the MS3 camshaft just use 4.10s ''Dont Fear The Gear ''
your car has less weight less offline torque will help you roll out with out spinning on the street
