228R + Milled AFR 205's
Old 04-14-2006, 08:09 PM
scotts94_z28's Avatar
Default 228R + Milled AFR 205's
Im looking for a head/cam setup for my summer driven DD A4 SS. I dont want to have to fly cut the pistons and would like to get 11:1 comp using milled afr 205's will this cam be ok? Also I'd like to be in the 11's with this setup along with a good stall (yank SS3600 or SS4000), fast 90/NW90 setup, Edelbrock stepped LT, ory, and slp dual dual would this be possible?
Old 04-15-2006, 08:28 AM
slow trap's Avatar
you shouldn't have any problems with that setup,i have a 228/228 with 5.3s shaved .030 and i think those afrs have more valve drop than mine does.
Old 04-15-2006, 11:52 AM
Orange99Z's Avatar
You should be in the 11's. I ran 12.14 an LS6 intake, Z06 cam, and stock LS1 heads, but my car is an M6.
Old 04-24-2006, 08:35 PM
Phil'sC5vette's Avatar
I want to know thw answer to
Old 04-25-2006, 11:51 PM
Old 04-26-2006, 12:09 AM
Layn_Low_247's Avatar
Originally Posted by Phil'sC5vette
I'm actually going to be running that same setup in my C5, except I'm shooting for an 11.2:1 ratio. You should be fine tho, they're usually setup w/ 224/228 .581/.588 114 cams, you'll be running a 228 .588 114 so I think you'll be safe. I've seen ppl run bigger cams w/ the same heads.
Old 05-24-2006, 09:14 PM
I ordered the 228R.
Old 05-25-2006, 08:55 AM
you2slo's Avatar
And I'm anxiously awaiting the results!
Old 05-25-2006, 02:52 PM
YO-EL's Avatar
I run 11.20 in the coldest weather to 11.60 in 95 degree heat..
AFR 205's, 224/228 @ 114 LSA..
Old 06-06-2006, 08:02 PM
I guess Ill see this weekend when my car goes into the shop
Old 06-06-2006, 10:01 PM
AlohaC5's Avatar
Phil - we need to get together and check out each others rides after the weekend. You're going to enjoy the upgrades! I recommended the TSP 228R to a co-worker with AFR 205 .59cc heads.
Old 06-06-2006, 11:33 PM
ShevrolayZ28's Avatar
Do you know if he'll be flycutting, or running a 0.040" gasket?
Old 06-07-2006, 08:46 PM
im going to be running to stock size gm gasket .051 or .054 dependant on who you ask. I plan on being at 10.8ish:1
flycut is not in the plan. Ill keep in my tr224 before I flycut
The AFR are milled to 63 CC
Old 06-11-2006, 05:20 PM
I dropped the car off to Phil97SVT today, and I should get the car back in two week. Its should be fun.
Old 06-11-2006, 08:00 PM
pdd
pdd's Avatar
Good Luck With It
Old 06-11-2006, 08:04 PM
You have to be excited. Sometimes I wonder if I should just pay to have someone do my work.
Old 06-15-2006, 02:00 PM
Ill F- it up if I did it.
Its better to buy in my book. Ill change the oil
Old 06-15-2006, 02:32 PM
I'll have results by Saturday. Car's w/ Wong's Performance right now, and should be done today if not early tomorrow. So we should be on the dyno either tomorrow or Saturday. It'll be interesting to see how much of a difference swapping to AFRs (62cc) from MTIs (66cc), upping the CR to 11.2:1, adding a 90/90 setup, and getting some tuning TLC from TJ will do for the car. (FYI: Also being added are new inj, plugs, wires, and pulley) Before I was at 403/378, and I'm thinking ~430-440/400-415 with the new setup through my A4 and IRS. We'll see though, I'll keep you guys posted.
Old 06-15-2006, 07:46 PM
with the 90/90 you should be in the 440-450
Old 06-16-2006, 04:34 PM
It's a mustang dyno, but I'll have numbers by the end of the day.
