COMP OEM LIFTERS ..Keep loosing prime
Depends on the pickup tube style, there are 2 different ones. One has a reciever groove, and one doesn't. The one with the groove needs the thicker O-ring, think its a brown O-ring. All the rest use the blue O-ring.
Could this be happening and mabye causing the knock.
Basically, I believe his oil pressure Indication of 20 psi at warm idle is nothing to get all rilled up about on a 98 car that gets the reading directly from the sensor-not the data bus as on newer Fbodies. Not unlike the reason why GM went with the idiot data bus temp gages too many old skewl peeps freak at the indications of these 98 gages.
As I said tho, with similar mods and similar tribulations I ended up with 7.350 hardened pushrods and spark table adjustments eliminating the metallic tapping noises that occured with some sustained 2500k rpm driving. Not necessarily high (5-6k) or anything like that-just over 2500 for a few minutes and bingo-tapping. Now that I have the problem resolved, I can flash the old (stock) timing tables back in the car and viola-more tapping.
This is not by no means an answer for the what seems like myriad of Tapping threads I have seen lately but, it did solve my problem.
Besides, If you went to the trouble of verifying the integrity of the oil pump pickup tube o-ring...
Tuning
Quiets down when heated but never really goes away. Can't tell if it goes away as revs go up due to engine noise. Oil pressure is still good.
Not trying to steal thread but looking for input.
One lifter still makes a hell of a noise at any thing above an idle the car will then run rough, odd missing and back fire etc. Have now decided to change them. But what brand to use?
My oil pump came with a blue O ring from TSP. I noticed that my old one had a slight rip in it. My old oil pressure was around 29-30psi at idle. Now its around 43 psi.
Did you reuse your seal? I orignaly installed the Oil pump with the old seal,but i found a new seal in the box TSP sent me, so i decided to change it, good thing i did because i had the O ring wasnt on good,also there was a smalll tear in the O ring.
Same thing happened to me. guy didn't have a new o ring so i reused his old on. it "looked" ok. started it up and he had low oil pressure. not REALy low so i let him leave like that. he gets half way home and his lifters start ticking they're *** off. I tell him to buy a new o ring and go install it at hid house. BOOm problem solved. he has super oil pressure now and no ticking.
