Knocking, after cam install, ADVISE PLEASE
Brandon
Brandon
2) Easy preload method with heads on, pull spark plug on #1, use a ziptie, or something rigid enough but not abrasive, bring #1 piston to Top Dead Center, TDC, by sticking the ziptie in the spark plug hole just enough so that when you are turning the crank your buddy can hold/feel the piston hit the ziptie. At that point you should hand tighten the rocker with socket/ no extension. When it is hand tight, with a calibrated torque wrench count how many turns it takes you to get to 22ft. lbs. Generally you are looking for 1/2 to 1 turn. With stock rockers, 228/228 .588/588 114 cam, PRC LS6 Heads, hardened 7.4 pushrods, on a stock bottom end 98Z I got 3 1/2 turns preload -way too much. I changed to 7.35 pr's. 90% of the tapping noise went away. I resolved the other 10% with timing adjustments with EFI Live.
3) What kind of tuning?
Good info. Its a 98 car, with a forged 2001 engine, I believe. Probably has around 15,000 miles on it. It is an old tune that was meant for the 224/.570 cam in it. But this is a serious metallic sound. I have to wonder if the MS3 and this setup would be more suited for 7.35 pushrods? The guys from TSP said the base circle of the cam and .015 off would be right with 7.4s.
