View Poll Results: M1, RP, or GC (FULL SYNTHETIC)
Mobil 1 5w30
249
40.82%
Royal Purple 5w30
195
31.97%
German Castrol 0w40
166
27.21%
Voters: 610. You may not vote on this poll
Mobil 1 Royal Purple or GC
Old 01-09-2007, 06:01 PM
  #141
habu2's Avatar
LSx engines, like many modern engines, have roller cams. Recently (a few years back) the flat tappet community started experiencing a lot of cam failures on new cam installs. Everyone started blaming the cam manufacturers but, after investigating, it was learned that oil manufacturers have reduced/eliminated the zinc content in modern oils. The zinc is a 'high pressure' additive that today's roller cams don't need. However, the 'old style' flat tappet cams/lifters still need the protection that zinc offers. That is why the 'old crowd' runs Rotella diesel oil - Rotella still has the zinc.
habu2 is offline
Old 01-10-2007, 10:44 PM
  #142
mullenh's Avatar
all correct except that we do use 'roller motors' in our racing engine in this 'old crowd' and we still want the 'zinc' so we use 'race oil' that is 'for off road use only'.
mullenh is offline
Old 01-16-2007, 04:13 PM
  #143
6techniques's Avatar
Mobil1 for me, Ive always used it and it has never given me any problems at all so if it aint broke, dont fix it!
6techniques is offline
Old 01-16-2007, 10:19 PM
  #144
98TA_vert's Avatar
I'm not voting because I only have experience with mobil 1. I have ran Mobil 1 and NAPA gold filters since I bought my car 2 years ago and at the most my oil consumption is 1/2 a quart in 3000-3500mi oil changes on a 98 TA with 97K
98TA_vert is offline
Old 01-23-2007, 03:13 PM
  #145
shakesvho's Avatar
RP from 3,000 on
shakesvho is offline
Old 01-23-2007, 03:23 PM
  #146
2QUIK4U's Avatar
Currently I run the RP 5W-30 but in the past I used Mobile 1. I have never had a problem with either. I have no experience with the Castrol. Other than the RP or Mobile 1 the only other oil I would personally use is Amsoil.
2QUIK4U is offline
Old 01-23-2007, 06:24 PM
  #147
GT500Guy's Avatar
I ran Castrol in the Shelby for years, but not the euro synth. Mobil One in several cars, with no problems. The Vette had it to start, and haven't changed brands. 72k fairly aggressive miles, and still no consumption between changes. Seems to take the temperatures well (it runs about 205F winter, closer to 225F summer). We put my wife's Grand Prix on it, too. Amzoil has been good, but a retired professor of auto engineering I know used to sell it and doesn't anymore. He advises M1, and uses it in his C4. I'm open to checking out alternatives, but will stay with the M1 until I'm sure of the change. Not because it's on my fill cap, but because the car is working well.
GT500Guy is offline
Old 03-22-2007, 09:04 PM
  #148
marv's Avatar
Mobil 1 for me...been using it ever since I got the car...has worked quite well.
marv is offline
Old 03-25-2007, 08:38 PM
  #149
ls1pwrdss's Avatar
Originally Posted by daryl2cb@yahoo.com
have you considered a catch can, upgrade your pcv valve, the oil your using is fine, I run it my self, others use the german castrol but is sometimes is hard to find. Is far as the purple, some swear by it, personally I would never run it, seems like a gimic to me, but I have never tried it so I really can not be a valid opinion as to its performance. But most that run it use the race blend 40, which I am told is the equivelent of a 5w-40.
if you want the german castrol just go to your local bmw dealer
i work for a bmw dealer and its what we use oil change intervals on bmw's are every 15,000 miles so i would say this stuff works
ls1pwrdss is offline
Old 03-26-2007, 12:36 AM
  #150
Third Gear's Avatar
I've had very good oil reports with the Green GC... in fact I have have about 5 oil changes worth of the stuff left. After I run out of that I'll probably use either the Amsoil Euro 5w-40, Series 2000 0w-30, or Mobil 1 0w-40.
Third Gear is offline
Old 05-01-2007, 06:54 PM
  #151
Bill Bowling's Avatar
I have been using GC 0w30 but Autozone does not have it anymore.
Bill
Bill Bowling is offline
Old 05-01-2007, 07:17 PM
  #152
TrickChassis's Avatar
um have any of you heard about the 2007 regulations on oil having less ZDDP/ zinc in it? everyone is talking about oil pressure and temperature and oil consumption. well that does matter but if your pushing low zinc/molly oils through your engine it doesn't matter what psi it's doing it at? In my big block Chevy i run Rottela T 15-40 CI4 not the new CJ4 with lower friction additives and lower zinc levels. but then again i guess i have an old school engine....
TrickChassis is offline
Old 05-01-2007, 11:09 PM
  #153
CaMaRo67RS355's Avatar
Rp In All My Cars
CaMaRo67RS355 is offline
Old 05-02-2007, 12:14 AM
  #154
ls1amit's Avatar
royal purple!! oil stays very clean.
ls1amit is offline
Old 05-02-2007, 08:03 AM
  #155
black01_WS6's Avatar
for people using Mobile one do some research on their product. It isn't what it used to be. There are many more oils out there that out perform, and are cheaper.
black01_WS6 is offline
Old 05-02-2007, 09:44 AM
  #156
SlowazzVette2's Avatar
Thumbs up
You know whats in my car ma' its that purple stuff.
I have been using RP for the longest. With tthat being said though I changed my oil every 2000 miles on my 98 Z28 and this will be my first change on my C5. I dont go very long without changing oil so I cant speak on it breaking down between intervals because I dont give it enough time.
SlowazzVette2 is offline
Old 05-02-2007, 10:54 AM
  #157
slt200mph's Avatar
You are wasting a lot of money and oil sir..synthetic oils will last a lot longer..I have 130,000 miles on mine (M1 0-40) with oil change intervals at 5000 miles ... the car uses 3/4 of a quart between changes and I run the car hard..it gets driven like a hot rod should...meaning it sees the red line (6800 rpms) every day .. I've had the oil analized and it has a lot more life in it after 5K..
slt200mph is offline
Old 05-02-2007, 10:57 AM
  #158
SS4Luck's Avatar
iev always used RP 10w30... but am switching to the 40wt race oil
SS4Luck is offline
Old 05-03-2007, 08:46 AM
  #159
502Stingray's Avatar
Simple, I tested it with friends, Mobil 1 kept a constant Oil pressure at the track, thru cold (morning) and hot (afternoon) Castrol actually dropped by a few PSI during the day.
502Stingray is offline
Old 05-05-2007, 10:01 PM
  #160
5_02ls1's Avatar
none of the above
5_02ls1 is offline
Quick Reply: Mobil 1 Royal Purple or GC
