torquer2 cam...
Old Apr 24, 2006 | 11:08 AM
99ccz28's Avatar
Default torquer2 cam...
im looking to get a cam..i have full bolt ons with a 3400 stall and 3.73 gears. i only want to rev my engine to 6k rpms, not any higher. i called tsp and the guy reccomended the t2 but im beginning to think that will be to big for what i want. car is a dd. please help me out and reccomend something that you think would be better if there is. thank you
Old Apr 24, 2006 | 11:17 AM
PREDATOR-Z's Avatar
Reving your motor to 6K is seriously limiting the choice.
You'll need a cam that Has a 38 to 40 IVC to benefit from the power earlier.
Check out some cams on VINCI site>>> sponsor like the 062 cam
If you want something a little more stealthy then my custom grind
210/224, .555/.567 115+1 LSA will also fit the bill.
Old Apr 24, 2006 | 11:18 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well, you can DD anything that has a decent tune allowing for that. Sounds like you have most of the stuff you need. I say get the cam, find a reputable tuner in your area and see what happens. Gears and stall combo should make it have less low RPM bucking, and Surge can be tuned out fairly easily.
Old Apr 24, 2006 | 11:24 AM
stevewix's Avatar
i've got one in my car, to be honest it's pretty lumpy; i'm SURE if it was on a 114 lsa instead of 112 it would run a lot smoother at the expense of some HP. you should be fine with a t2 as long as it's not on a 112lsa.
99ccz28's Avatar
thank you for the replies.....im not worried about it being stealthy, i would rather it loped a little so you could tell it was there.
as far as the tune goes i am thinking of getting a mail order tune from tsp (if i get one of their cams) would that work good...he said they give very good tunes. thanks
Old Apr 24, 2006 | 11:57 AM
99ccz28's Avatar
can anyone else give me any ideas?
Old Apr 24, 2006 | 12:03 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Where are you located? I hear the the TSP tunes are pretty dead on. Especially since they know that cam better than anyone else does as far as tuning I am sure.
Old Apr 24, 2006 | 12:06 PM
99ccz28's Avatar
im located in pennsylvania, that is why i was thinking of getting a mail order tune from tsp if i go with one of their cams
Old Apr 24, 2006 | 12:11 PM
HolyShiznit's Avatar
I have the TSP T2 with their tune in my Vette. I daily drive it and I don't even have gears. I find it easy to drive.
Old Apr 24, 2006 | 12:51 PM
PREDATOR-Z's Avatar
You guys are only reading between the lines. He said he didn't want to rev higher than 6000 rpm. I had a TQ V2 and it peaked at 6300.
So no the TQ V2 is not the cam for what he wants.
If he want to shift at 6000 then his cam needs to peak at around 5800, capiche
Old Apr 24, 2006 | 12:56 PM
99ccz28's Avatar
thank you...what about the 228r from tsp..would that fit me better or is that still a little to big?
Old Apr 24, 2006 | 01:04 PM
hammertime's Avatar
What is the reason you don't want to take it past 6000? If you are dead set on it, then PREDATOR-Z is right, look into something else. If you think that 6000 is some magic number you should not exceed, then perhaps you should consider that most cam changes will require spring upgrades and PCM changes. If you get matched components from TSP with their tune, then taking it to 6500 should not be any problem.
If you are set on 6000, then consider the TSP 220/220 cam, or the 224R. But get it with the 112 LSA, or ask about a custom grind for your requirements.
Old Apr 24, 2006 | 01:06 PM
PREDATOR-Z's Avatar
This is what I recommend: You can buy it here (VINCI)
http://www.vincihighperformance.com/...%20LS1%202.htm
062 cam
DUR @ .004" 272*/280*
DUR @ .050" 210*/218*
LIFT .551 / .551
OVERLAP 52*
LSA 112*
It is lopey, easy on springs, great trq down low and midrange, and you can shift it at 6000 rpm since it peaks around 5800>5900
Old Apr 24, 2006 | 03:32 PM
99ccz28's Avatar
that is why i came here because i thought the t2 was a bit too much for me and i am going to look into something else. no its not a "magic number", i just dont have the money for a new short block if i break a rod bolt or something and i feel i have less of a change of doing that if i dont go to high with the rpms, and i know that i will need new springs and pcm changes.
Old Apr 24, 2006 | 03:44 PM
Patrick G's Avatar
LS1 Tech Administrator
Thunder Racing has a new Torque Series of cams that might appeal to you.
224/224 .563/.563 110LSA +2
This cam is easy on springs (you can run Comp 918s) and it will make peak power by 6000 and will maximize the power under the curve.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Apr 24, 2006 | 03:53 PM
PREDATOR-Z's Avatar
you can go to 6300 rpms without any fear.
Old Apr 24, 2006 | 04:21 PM
99ccz28's Avatar
yea maybe for a normal person but honestly i have fear going to 6000
Old Apr 24, 2006 | 04:32 PM
99ccz28's Avatar
062 cam
LIFT .551 / .551
OVERLAP 52*
LSA 112*
what kind of horspower and torque does this cam make? is there a graph anywhere for one? thanks
Old Apr 24, 2006 | 04:42 PM
mrr23's Avatar
i put that one in my wife's car. picked up 30 rwtq and 22 rwhp. even the wife said, it seems to accelerate quicker from a stop now.
sound clips
rev in park
idle in park
idle in drive
Old Apr 24, 2006 | 04:50 PM
99ccz28's Avatar
wow thanks for everything mrr23...so it made 357 hp..is that a full bolt on car?
