oil accumulator???
Old Apr 24, 2006 | 05:07 PM
65chevellels1's Avatar
Default oil accumulator???
anybody use one of these on their ls1? if so where did you tap it in? I am doing a new LS1 build and i thought it would be a nice way to pre-lube the engine before i start it.. as well as for when it sits in the garage over winter, ect.
http://store.summitracing.com/partde...5&autoview=sku
Old Apr 24, 2006 | 05:16 PM
ROCNDAV's Avatar
I've been thinking of doing this. There was someone that was talking about doing a GP on the complete kit last year. I think he worked for Andy @ A&A Corvette.
Old Apr 24, 2006 | 05:25 PM
Really?? i really think 137.00 is cheap insurance considering what i have invested overall.. make me sleep better at night.. lol
Old Apr 24, 2006 | 07:27 PM
ls1 1990 VN's Avatar
I have one on mine, 3 qrt. my oil filter is remote mounted due to restricted space with LS1 transplant.
The accumulater is connected with a T join. I also use an electric solonoid to operate it so i can turn it off and on at will.
Old Apr 24, 2006 | 07:36 PM
awesome.. what remote mount did you use, and what solenoid did you use to operate.. part numbers or place of purchase would be awesome..
Thanks
Old Apr 24, 2006 | 08:47 PM
Car is in the work shop with a lifter problem so i cant even have a look as i cant remember brand name of remote mount but any speed shop sponsor should have or get them. The solonid was i think purchased from canton who make the accumulator by the workshop i use! i will check with them.This was all done 3yrs ago so please excuse my bad memory. I'm also in N.Z.
Old Apr 24, 2006 | 10:29 PM
ROCNDAV's Avatar
Thats what the kit was, remote mount and electrical kit which would delay the starter a sec or two until the presssure was up.
Old Apr 25, 2006 | 08:31 AM
Hey.. i just ordered a Canton Accusump accumulator with electric valve so it will open and close itself with the ignition switch.. just havin troble figurin out where to plumb it in now
Old Apr 25, 2006 | 01:21 PM
Remote mount the oil filter and T it into the oil line. you guys will have some one over there that will carry the parts in stock.
Old Apr 25, 2006 | 02:02 PM
ROCNDAV's Avatar
So do these remote mount kits have hard lines going from the filter location over to the front bumper area (or somewhere else)? I am going to be running LTs and wondered if there would be an issue.
Old Apr 25, 2006 | 09:52 PM
427's Avatar
427
We sell a -10 fitting that has the correct thread to put in the block oil galley. It would work on the drivers side low hole that comes out of the block, or the one by the back of the intake. If you use the one at the back of the intake, you should drill the block out at that port too the main oil galley with a drill around .400 before use(assuming the engine is apart).
Kurt
Old Apr 25, 2006 | 11:29 PM
racecar's Avatar
I just installed a 2 Qt Accusump with a manual valve. Put it behind the passenger seat, on the floor . I didn't like paying for all the stainless hose and fittings, or adding the weight, but now that it is installed I really like to see the oil pressure rise to about 25 lb before I start the motor every time..... I put the hose in where the oil pressure sensor was, and moved the sensor to the front of the block, drivers side. I drilled out the hole just like Kurt said. Kurt:: Thanks for all of the ideas last year when I had oil pressure problems. Turned out to be oversize cam bearings, and the pickup was on the bottom of the pan due to the height of ARP 12 point nuts and washers. dumb mistake
Old Apr 26, 2006 | 12:25 AM
Hey guys.. good info here! I am kinda thinking about instead of using a remote oil filter, using a "sandwich" oil filter port, and then using that to put in a oil cooler, and then tying into that system? Should work, get a little extra oil capacity, and also a little cooler temp.. remote mount wont benefit me.. cant drill cuz just got engine together
Old Apr 27, 2006 | 11:17 AM
anyone else use these?
