Ticking, Knocking noise! checked pushrods?
Old Apr 24, 2006 | 08:39 PM
Mudvaynemike1's Avatar
Default Ticking, Knocking noise! checked pushrods?
I read thru the forums and ever one states that the noise is pushrods! It comes from the the driver side only so I opened up the vavle cover and checked all the pushrods. They were all good. It started as a very suttle knock after I busted a small donut down the street. Thought I had it under control but once those tires broke loose it maxxxed out, so I let off and it has been slowly getting Louder each day (1995 Camaro Z28)
Old Apr 25, 2006 | 12:12 AM
MightyBobo's Avatar
Rocker arm bearings? Do you smell exhaust in the engine bay at all?
Old Apr 25, 2006 | 07:54 AM
Not that I can tell. I am gunna put my valve cover back on today if it doesnt rain and check my plugs. But it sounded like it was coming from that damn driver side valve cover instead of under the headers.
Old Apr 25, 2006 | 08:15 AM
MightyBobo's Avatar
For the longest time I had a really annoying tick that I had suggestions from a bent rod, rocker arm bearings, to a dead cylinder. In the end it was nothing more than a lose AIR block off plate that was bouncing up and down heh. Yeah, I would feel around your plugs and see if any are loose. Possible it may be a header/manifold gasket too.
Old Apr 25, 2006 | 08:20 AM
MagikMan's Avatar
Honestly man, you should check your spark plugs... make sure they are secured and tight... chcek the connections, you just might be good to go.
Old Apr 25, 2006 | 08:22 AM
MagikMan's Avatar
Speak of the devil!
https://ls1tech.com/forums/showthread.php?p=4683254
Old Apr 25, 2006 | 10:42 AM
01formula6's Avatar
Haha, you beat me to it. I was going to reference my thread also. Check the damn plugs, if that isn't it, at least you ruled out that possibility. Ticking soud = super annoying.
Old Apr 25, 2006 | 04:57 PM
Not only is it annoying but its scary! I dont wanna get on it and have my engine **** out ya kno!
Old Apr 25, 2006 | 05:09 PM
Zymosis's Avatar
I noticed a different valve train sound for about a month. I checked everything I could check. Then a month later a rocker arm lost its needle bearings.
Other things to check:
AIR system
Make sure plugs are tight
Pushrods / Rocker arms
Valve Springs
Lifters
Old Apr 26, 2006 | 10:18 AM
Well my rockers seem alright! what the hell is going on here! I do not want to bring it to the shop, I refuse it. Must fix this in house. How can I check my lifters?
Old Apr 26, 2006 | 10:53 AM
MightyBobo's Avatar
A nightmare. Gotta yank the heads to check on those as far as I know, and - judging from just the work it'd take to do the valvetrain, heads are no fun heh. Im only assuming btw, since I was afraid I might have to check MY lifters at one point, and it ended up being something stupid. Ive been told left and right, that the lifters should be the last thing to check. You checked all your spark plugs?
Old Apr 26, 2006 | 12:14 PM
Zymosis's Avatar
Yeah, check the easiest things first, theres no reason to pull the heads and check the lifters, when you have a bad plug or plug wire.
But to check the lifter, you will have to pull the heads.
Lifters are in the rectangular holes at the top.
Old Apr 26, 2006 | 12:19 PM
SHINER's Avatar
What damage could arise from a bad header gasket?
Old Apr 26, 2006 | 02:15 PM
What is the best way to attack the passenger side spark plugs and wires?
Old Apr 26, 2006 | 02:39 PM
Zymosis's Avatar
-Your car will tick loudly/idle poorly...
-May cause it to run rich with this situation
-Running rich can fowl out plugs and ruin O2's if it is bad enough
With the right tools
http://www.installuniversity.com/ins...g_and_wire.htm
or
Most people / write ups will say use and extension/swivel, but the 2x I have done it, I can just reach back there and get it.
I do not have small arms by any means, but they may be longer than other peoples. I start at the front of the engine, and reach right along it, under the coil packs (slightly left/lower than the vavle covers), and I can reach it from infront of the car. (Using my left arm) Using this method / similar method, I can change all the plugs with a standard 3/8 ratchet and spark plug socket.
Old Apr 26, 2006 | 03:15 PM
SHINER's Avatar
thank you.
Old Apr 26, 2006 | 03:40 PM
MightyBobo's Avatar
Just a little ambition, changing/checking plugs is heaven once you get some headers on
Old Apr 26, 2006 | 04:04 PM
DaddySS's Avatar
Remember gang - 95 = LT1, not LS1
Old Apr 26, 2006 | 04:05 PM
MightyBobo's Avatar
Good point, forgot he was in a 95. Course, this IS LS1Tech, eh?
Old Apr 27, 2006 | 08:40 AM
Come on, dont hate. Its all in the family. I was wondering if it turns out to be a rod about to go where is a good place to start looking for a crate engine? If I gotta do it over again i am gunna do it right Get as much as I can out of this car. Or maybe drop an LS1 instead of the LT1 (if at all possible)
