View Poll Results: Are the Dart heads worth the extra money?
YES-Dart's are much better!
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
149
45.02%
NO-PRC LS6 CNC heads are good enough!
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
182
54.98%
Voters: 331. You may not vote on this poll
Are Darts worth $600 more than TSP's LS6 heads?
#42
Originally Posted by Jason 98 TA
We're all shocked that you don't like any other CNC cylinder heads besides AFR's. We would like to extend an invitation to you personally, Patrick, to join us on the engine dyno in the next few weeks. We will be dynoing the as-cast Darts, AFR 205's, and a set of our PRC 1.0 LS6 heads on a stock short-block. It would be nice to have a few more witnesses to see the cylinder head swap procedure, as well as all of the results, no matter what they are. It would be even better for you to be there since you're so fond of the AFR's, and continually have the need to down our products.
Feel free to give us a call if you'd like to be there, and we'll let you know on the exact date and time.
It's a pretty simple comparison. Your always quick to down our cylinder heads like they won't make good hp... Here's your chance to get data to support your claim.
The PRC stage 1 LS6 heads flow great air flow for the $$ & make very nice power gains.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#43
Galen,
Currently we aren't offering anymore cnc ported Dart heads. Maybe at some point we will do them again, but currently we've stopped the CNC porting of Dart castings.
How come???? Is there a problem? What about the people that bought them? C'mon, let's here it.
#44
The heads are all ready making a name for themselves, i think they work well will the MS3. I'm thinking of pulling my heads and milling them some, changing my exhaust and headers so these heads can show there full potental. I know everbody is waiting to see what they can do with a custom grind but i'm not expecting number much better than the MS3 if any. Don't forget i have a MS3 so i'm bias.
Steve
Steve
#45
I'm just guessing but i think they are pretty busy with the LS6 heads at this time, Plus i think Patric had mentioned earlier they are pretty good out of the box.
#49
Super Hulk Smash
Jason, will you guys be doing a Stage 3 with the LS6 heads? I know with the 12cc Mahle pistons, a 72cc or milled down to 67cc head provides no compression for the big cams that go in a 402.
Without the Darts and no LS6 casting, that limits piston selection to the Diamond flat tops.
#51
Originally Posted by SVT THIS
I was up all night last night reading through the Dart 205 and 225 posts made in the last 6 months. I haven't really seen any flow numbers that impressed me, but when on a car with a good cam and supporting mods I've seen some real impressive power (440+hp).
Would you all say the Dart 205/225 heads are worth the $600 or so more dollars over TSP's LS6 head? And are the CNC Dart heads worth the extra money to get them CNCd? Wouldn't that change the runners?
Does anyone know if the PV clearance is stock on the Dart heads? I'd still like to run a larger cam with a set of 225s but don't know if that would be an issue.
If you have a stock cubed motor, you will sacrafice more from the 205 rather then the 225's. The 205's will give you more power down low, and while most cams take away power from that area, it is usually a good idea to equal things out a bit. I have been really impressed by what I have seen from these dart heads..... comparing flow numbers is like comparing dyno numbers, so just keep that in mind.
You ask the question if dart is worth the money over TSP..... it all depend on your budget...... IMO the dart head is a better head then the TSP, but they are in 2 completly price ranges which equals them out quite abit. I have seen very impressive numbers from the TSP heads..... Figure out the total cost of each set-up (including spring upgrades, valves, etc.) If you feel you can use that $600 to put towards a rear-end then it might be worth saving a few bucks..... everyone's build is different and everyone handles them differently.....
Again I hope I didn't jump out of line and repost anything, I didn't read this whole thread
#54
i had the darts cnced from tsp and teh pv clearence with them was 0 with my Ms3 so i sent them back... i am not gettign the ls6's. Jason told me they were having smoke problems with them and that there valve drop was diff. on seprate heads. thats teh reason i got out of him
#55
Steve
Steve
cometic, with valve reliefs of course. I'm sure the numbers would make you very happy.
#56
Originally Posted by Ksett
I would love to see what your combo makes milling them to 59cc and a .040
For the record i have no smoking problem and haven't heard anything of this problem and i have spoken with Trevor and Jason this week..
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Steve
#58
I'm going to drive her at the current power level for a few months then i'll perform the mods listed above. I would hope to see atleast 30hp and 15ft.
Steve
Steve
#60
Originally Posted by vettenuts
The smoking he is referring to was with the Darts. It was one person and it was never confirmed what the problem was. I disassembled mine to hand sand the ports and smooth them. I carefully removed the valve seals and re-used them. I have zero smoking problems or oil control problems with my Dart heads. I have a feeling that there is more to this smoking story that never came out, because from what I understand they were also pushing the valve cover gaskets out of the valve covers which indicates more serious issues.
Galen
