torquer II and everyday driver
Pred, When computing for DCR on the torquer, what IVC numbers are you using? I have been using the IVC at .006 number on the cam card, which is 71* on my cam with 2 degrees advance. Should I be going off the .050 IVC number and adding 15 before computing?
Also, I have the T2 cam in my daily driver, but I drive mostly highway, and i have heads. The added compression makes the t2 drive better than my f-13 was with stock heads. I probably wouldnt have gone so big on the cam if I drove mostly city miles. Since Im 80% highway, i think its perfect. It does take a little extra car driving in traffic though.
Originally Posted by PREDATOR-Z
Yeah it will perform. Better with juice since juice will raise cylinder pressures.
If you could raise the DCR to 8.5 you could gain another 10>15 rwhp.
Originally Posted by Quik
how much? im already at 10.9SCR
http://users3.ev1.net/~black_ops/cam...calculator.xls
You need the advertised duration numbers at .006 which are 281 and 283 respectively.
For some reason I got you at 10.97>11.01 SCR depending on your piston deck height (but no accounting for gasket bore area.)
To optimise further 11.5 SCR and 8.56 DCR with 61 cc
and 11.67 SCR with 8.67 DCR with 60 cc
Keep in mind those figures are a close ballpark not exactly accurate due to the variation in parameters. So it is always good to take the least figure to avoid going over.
see this might be a problem with your pistons,
so you think ill have P/V issues right now?
Are you stock valved? (I mean your motor LOL)
Not right now, but if you mill or reduce gaskets (the trick is how much can you go without PTV issue)
yea stock 317 valves carried over to the 243 castings
I would measure PTV with a dial and get true values.
Then using a thinner gasket, I would raise the SCR/DCR as much possible without causing any PTV issues.
By doing this you're killing 3 birds (SCR/DCR and Quench)
Makes sense?
