View Poll Results: Which of these 4 cams is KING of big cams?
TRex
140
41.92%
MS3
101
30.24%
F15
19
5.69%
G5X4
74
22.16%
Voters: 334. You may not vote on this poll
TRex vs. MS3 vs. F15 vs. G5X4
Old 07-06-2006, 01:52 AM
  #121
ditty24's Avatar
Tonight I put the cam in Nother week or so and some f15 #s!!!
Old 07-21-2006, 02:46 AM
  #122
chewy99ws6's Avatar
I like the MS3
Old 07-24-2006, 10:13 PM
  #123
Arizona Mike's Avatar
Originally Posted by Matt D
Why would you spin a G5X3 or similar cam to 8000 rpms just to see what the curve is like? I call on that. Sorry, but it is stupid to do that when that cam as well as similar sized one peak at around 6600-7000. I only have to spin my motor to 6600 to run 10s, on motor, in my daily driver. You might want to look into another cam/spring package that makes more useable power. Let me know if you are interested in a custom Outlaw Motorsports cam grind & Patriot spring kit.
He was probably checking for valve float to figure out where to set his redline. Not so foolish.
Mike
Old 07-25-2006, 02:12 AM
  #124
HottLS1Z's Avatar
MS3 here. Went 12.12 @112mph with 2.73 gears and COMPLETLY STOCK suspension, no subframes, lca's or anything. This was on a 1.7 60' with 18" Kuhmo street tires too.
Race weight was 3650. Are those considered good #'s? It dynoed 362RWHP with the converter not locking up and some driveline vibration from the steel driveshaft being spun to 140+ mph on the dyno from the 273 gears.
Old 07-28-2006, 01:25 PM
  #125
ditty24's Avatar
Well i got the car running last night on the stock tune and it needs a tune bad ,but im getting it dyno tuned at Doug Rippie Motorsports next week
Old 07-28-2006, 06:44 PM
  #126
ALL UC2's Avatar
well, my numbers are in my sig. i have a th350(non lockup) and 4000 stall and 4.10 gears and put down 366 rwhp. car runs CONSISTANT 7.42-7.44 in the 1/8th. car weighs 3300 or so(guess)
Old 07-29-2006, 03:51 PM
  #127
BREAKPARTS's Avatar
I Cant Figure Out How Some Ls1's Can Have Boltons And Acam Like The Ms3 Or T-rex...both Good Cams Only Making 360 Rwhp 380 Rwhp..my Bolt On Only 02 Z28 No Pulley,made 360 Rwhp No Rockers,no Cutout..im At Aloss For Words...and With Ms3 Cam And Injectors 415rwhp...im Hoping A Pulley 90/90 And Stage 3 Ls6 Heads I Want 470 Rwhp......but Some With These Same Mods Make So Little Numbers...is This Due To The Tune Street Vs Strip
Old 08-03-2006, 11:35 PM
  #128
ditty24's Avatar
well i got my cay dyno today F15 ect and it put down 395rwhp & 380rwtq This is the first camed car iv ever driven so i have nothing to compare it with but with the tune about 75% its fine for a daily driver! It kinda seems slower till 3-3.5k rpms but then it pulls hard as ****. I have shift point at 6500. List of my parts are Futral F-15 cam ,Kooks 1 3/4 & 3x3 xpipe with no cats ,Ls6 intake <42# injectors ,ls6 oil pump ,160 tstat ,futral 7.4 rods ,manhley springs ,Haltech stinger intake ,B&B catback ,TR6 plugs & Msd wires. The car is a 99 vette mn6 with 80k on the motor. ditti
Old 08-05-2006, 08:46 PM
  #129
BREAKPARTS's Avatar
**** the t-rex IM SNIFFIN AT THE MS4
Old 08-05-2006, 09:33 PM
  #130
~JOSHUA's Avatar
421 rwhp/ 384 rwtq after tuning with a Lunati 236/236 .580 .580 112 LSA with -0- advance ground in. Very good drivability and it pulls like a beast, it doesn't get too much better N/A cam only on stock cubes.
Cam only, pulley, Shaner S3 throttle body, Hooker, ORY, SLP DD catback, 4.11 gears.
You don't need to slam the valves with a huge cam lift when using stock heads. There is a point of diminishing returns. ~Josuha
This was N/A about 4 months ago. The car now has a twin turbo.
Old 09-14-2006, 03:48 PM
  #131
DanZ28's Avatar
No numbers but my times are in the Sig. Before the TRex and the TH400, I put down 462/425 with a 230/234 cam, TRex should have better peak numbers though. No doubt the dyno is useless for a TH400 setup so we did the tuning on a deserted road and didn't worry about dyno numbers, the track prooved it worked.
I love the TRex, no way I'll go with an MS4 unless someone has astounding track numbers with it.
Old 09-15-2006, 06:29 PM
  #132
TheZaZ's Avatar
Hell...I have the Patriot Gold Dual valve springs. I have 40 or 50 runs on them and I shift at 6800-7000. Im happy with them.
Old 09-15-2006, 06:47 PM
  #133
silverdub6's Avatar
Originally Posted by CraZee ZO6
Dont ls1's also crack 400 even 410 with the ms3 cam.
You can crack 400 with a tr224!
Old 09-15-2006, 08:45 PM
  #134
import slayer's Avatar
I love my Trex. I DD it and I have no problems with it. and it makes awesome power
Old 09-19-2006, 01:02 PM
  #135
SVThis's Avatar
u use a 2800 stall with the T-Rex?
Old 09-22-2006, 06:04 PM
  #136
Chris Gage's Avatar
Isn't that stock size???? Is that really possible???
Old 09-26-2006, 08:25 PM
  #137
eamador11's Avatar
did this boy ever pick a cam yet? lol
Quick Reply: TRex vs. MS3 vs. F15 vs. G5X4
