View Poll Results: Which of these 4 cams is KING of big cams?
TRex
140
41.92%
MS3
101
30.24%
F15
19
5.69%
G5X4
74
22.16%
Voters: 334. You may not vote on this poll
TRex vs. MS3 vs. F15 vs. G5X4
This is the end all of big cams thread. Post up what cam, heads, bolt ons and gear/stall you are running with. Post up your numbers and times and lets compare the bigger cams available now and see who's the best
P.S. Lets keep the "those cams are to big" comments out of this thread.
You need to set some goals and pick a combo to meet them. You have been all over the place with all these polls, just let use know your goals and we will help you meet them.
Steve
Originally Posted by Kounsy
go custom grind, and go with what u want
do you just want to know about a big cam to get? or do you actually want a cam that will make you power? or are you just wondering what the biggest of these cams is?
01 ws6 trans am with bolt ons only here....stock cam, stock block, stock pistons....only external bolt ons and my tuning... 365HP and 385TQ
Nick has LS6 heads, and the G5X2 cam and is making ~430rwhp and close to that of tq....biggest won't make the most power all the time. Its all in the setup
Originally Posted by Ksett
Yes, I agree to get a custom grind after you figure out all your goals and your mods you will eventually go with. Then research the heck out of what type of grind you will need. This may involve the forum plus tuners. Good Luck!
find out what u want and call some of the companies and get what u need
Originally Posted by lilbuddy1587
MS3 doesn't hold a candle to the x4 or the T-rex. Both have VIOLENT midrange tq and power.
LS1TECH Sponsor
Where has the ms3 proved in cant produce big #s?
It produces big #s on CAM only applications on LS6 cars.
01 ZO6 put down 433rwhp cam only.
03 ZO6 put down 441rwhp cam only.
Stock ls6 untouched heads.
With TSP's ls6 heads for 899 it put down 468rwhp.
Dont ls1's also crack 400 even 410 with the ms3 cam.
Why do some hate on the ms3? and some love it to death!
