Sounds like I have pebbles in my motor when I get on it?
Was at the drag strip today and noticed that when my car got up into the high rpm range, it sounded like I had pebbles in the motor. Could this be a result of a bent pushrod or bad rockers? Anyway I think it is bad enough that the motor is falling flat on it's face when the noise starts. This is 99 LS1 motor with about 54k on it. The motor is well maintained but this has me concerned. I don't know where to start. It has fresh plugs, fresh oil change, sea foamed the top end, crankcase oil before change, and fuel. Just want to know if this could be the result of a bent pushrod, or loose rockers????
Originally Posted by Cam72aro
I am pretty sure that these are the same thing, pinging is just the slang term for detonation. It all occurs when the fuel is ignited before the spark plug fires. Either way, its the same thing.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Yep, detonation is uncontrollable combustion as opposed to a controlled combustion. Caused by unstable fuel charge maybe too lean etc.
Preignition as discussed caused by local hotspots usually, which means it diesels combusting prior to the official spark release.
