need a H/C combo that passes smog!
Let me know of any other combos that would pass Smog as well, and the expected power levels, Im not too worried about streetability, as the car will be a garage queen in a year or so.
From what I've read here the 224/224 114 LSA is the biggest you could go with and still pass. When I was out in california I called a few performance shops and two of them said they had their own cams that would pass both were slightly bigger than the one I mentioned. I was told getting 420 rwhp was possible on their packages without headers. Sorry I don't remember the names one was up north the other was in or around san diego. the packages were expensive for them to install parts and labor was as much as a supercharger 5000-6000 dollars. If your going to spend that kind of money might as well go that route. At least with a charger you can easily take it of and sell it. I would call a few shops and see what they say on which cam to go with, since they have lots of experience with getting cars to pass.
Go with a cam no bigger than a 224 on either side and a lsa of 115 and a really good tune and you should be set. I am still waiting on the verdict of the rhoads lifters i will be running. car should be done fri or sat. Go with a Ls6 or hot cam to play it safe. For heads have your stockers gone thru to match cam , I cant justify spending 2K for heads. Now 600 for valves and valvetrain upgrades well worth it, cheap insurance.
Really? Then why is it both of my 1999 c5's pass every two years with Kooks and Dynatech long tubes? How is it your car passes?? It's just as illegal as mine with your logic.
I run jba shorties that have carb numbers and modified LS6 for Egr compatability, my cats wont move an inch i have factory 241 heads and my cam isnt big. Lt's move the cats out of the preferred heat temps emmissions requires..so you have a inside guy that helps ,why pay fee when you dont have too. this is exactly why you wanna stay in the legal area of smog. IMO its a royal pain to jump thru the hoops. i am not trying to be critical it just that there are more and more mobil testers running around that can pull you over and have you open the hood..i am sure your vettes are sweet
I don't pay anyone extra anything nor do I jump through hoops. My point is, by the letter of the law, your car is not legal, same as mine.
Saw one thing that irked me in this thread and that was someone telling this guy that hogged out heads cause poor throttle repsonse. That is an absolute bullshit statement. Porting and polishing your heads will not effect passing smog either.
So your heads "should " be CARB certified.
LTs/ Mid length are NoNos only CARB certified shorties.
As far as cam, 224, 114 will pass but that includes good functioning Cats and a good tune.
What passes at the station could foul up by the week after if you are borderline.
-6>-7 overlap cams are more of a sure bet.
You can't use LSA to decide which cams will pass and which won't. There's more to it than that. It's the overlap you are concerned with. You could pass on a 111 if your cam had -3 to -4 overlap ot .050. As a general rule, most need less than -3 overlap to pass.
Thats not a good rule of thumb to go by. He said he's "pretty sure" he wants the TR224, which will pass on a 114, but if he decides to go with another cam he'll have to figure out the overlap. There are OTS cams that will not pass on a 114. You can buy the 228R on a 114 that won't won't pass, or you can buy the TSP 233/239 on a 114 and it definately won't pass. If you want to make sure to pass the sniffer, you will have to calculate overlap and not go by LSA.
