LS2 timing chain
Old May 1, 2006 | 11:02 AM
you2slo's Avatar
Default LS2 timing chain
Should I purchase just the LS2 chain or the entire timing set? I'll be doing a cam swap and want to upgrade the chain and oil pump.
Old May 1, 2006 | 11:40 AM
01formula6's Avatar
You just need the chain (part# 12586482).
Old May 1, 2006 | 11:48 AM
you2slo's Avatar
Unless the gears are worn, right?
Old May 1, 2006 | 11:52 AM
FstBlkz28's Avatar
If the gears are worn, then yes - go ahead and replace them. How many miles are on your car?
Mine had 67k on it when I did my cam and my gears were fine. So I just used the chain.
Old May 1, 2006 | 01:09 PM
you2slo's Avatar
I have just over 43,000. I don't want to get in there then realize I should have just ordered the entire set.
Old May 1, 2006 | 01:32 PM
hurley711's Avatar
Fred Beans has the chain real cheap
Old May 1, 2006 | 01:57 PM
REDWS6ROCKET's Avatar
just the chain, unless gears are worn very badly.
Old May 1, 2006 | 01:58 PM
FstBlkz28's Avatar
Just get the chain. @ 43k, you shouldn't need the whole gear set and stuff. Just the chain will be fine.
Old May 1, 2006 | 02:31 PM
GuitsBoy's Avatar
i cant remember ever seeing a chain worn badly enough to warrant new gears
Old May 1, 2006 | 02:40 PM
you2slo's Avatar
Sounds good, I didn't want to spend the extra $50 anyway.
silverlt1ss's Avatar
get the kit, it's only 80 bux. i heard after a 100 miles or so the chain loosens up on the ls1 sprockets
Old May 1, 2006 | 02:58 PM
stealth71's Avatar
Is there anymore input on this (Chain only vs Chain and Sprockets)? How hard is it to change the crank sprocket? Where is the best place to buy these?
Old May 1, 2006 | 04:30 PM
ShevrolayZ28's Avatar
The chain and sprockets wear together as a matching set. The distance from tooth to tooth on the worn sprocket will be mated with the matching links on the worn chain. Popping a new chain on a worn sprocket is not the right thing to do IMO.
A few more bucks gets you both. I would replace both, or niether.
