valve noise, adjusted rockers a million times
Old 05-05-2006, 08:52 AM
RALLDU's Avatar
ok now. where would it be possible to get the info i need or the steps that are involved in this. then maybe ill be able to narrow down the problem and maybe eliminate it all together.
Old 05-05-2006, 11:24 AM
ShevrolayZ28's Avatar
Maybe having a look at this thread would help.
https://ls1tech.com/forums/generation-iii-internal-engine/493743-easiest-way-check-lifter-preload.html
But I'm not sure being off on the preload by a little would cause your oiling problem.
