TSP/PRC Stage II Darts. Smoking issue.
#161
Originally Posted by vettenuts
Are yours the TSP ported version? Did you check your retainer to seal clearance?
My heads had 8 out the 16 seals torn, I mean they were torn real bad. I replaced the seals with good ones, not the cheesy ones that came on the heads.
My car does not smoke at all, makes lots of power and runs great.
I really think the problem everyone is having is in the seals.
I can't wait to do some more tuning and then hit the dyno.
Oh, some more inf.
I'm running all factory PVC setup on an LS2, everything, nothing un-plugged, re-routed or unhooked. The only thing I changed was I put a breather in the oil spout.
#170
You have the PRC springs, correct? Do you also have the dual spring seat? If you do, then they shouldn't have used the original Dart seal because it already has a seat on it and you may have been out of clearance with the retainer. Also, the seal may not have been sealing because of this.
#171
The seals were ripped to hell, that's why they wouldn't seal. I'll get one of my old ones and post a photo of it tomorrow. You'll see why they would have smoked.
8 out of the 16 were like this. The tops were ripped about half way around each one.
I'm using whatever springs and seats that TSP put on them. The seals don't have anything to do with the spring seats on my heads? Other that they have to be pretty narrow to fit inside the inner spring.
#172
#173
Ok, I have put 400 miles on my heads so far. I get a 007 smoke screen when I hammer down WOT. So much oil I actually see oil spots on the back of the Vette bumper area. I have the Factory assembled Dart 225's with the Beehive springs. What is a good aftermarket seal that will work for me without changing the springs? The blue ones in the pics are different and may not work with the beehive setup. BTW installed a catch can, and it makes no difference. Who else has a 007 smoke screen at WOT?
Thanks,
Mike
Thanks,
Mike
#174
Mine don't use any at all. I "think" the 02+ GM seals will work, I measured them and they seem to be basically the same seal, with a very slightly thinner base (around 0.005" if I remember correctly).
You don't mention what cam you are running, but the setup on the Darts is 1.750" installed height. Did you measure/compute your retainer to seal distance? I have some measurements, if you have you cam lift I can give you some approximately values. Just in case it is your lift that took out the seals.
#175
No intent of hijacking the thread.. I have the identical problem with Patriot LS6 heads, a ported oil pump. I have changed seals, sealed rocker threads, no change.
I just finished converting to the LS6 valley PCV and a catch can - will run and see what happens. Consumption was 1 qt in 200 miles, no visible smoke except when starting. Plugs, intake condition identical to photos presented so far. Just another data point.
#176
