ET 215s with 233/239 or TRex?
I've got both cams and am not against trying them both. But if I reach my goal right off the bat with one or the other I probably won't try the other.
so looks like you gots to go with the other cam.
IIRC, his pistons were flycut, but that was for his stock 15* heads. No need to flycut with the 11* ET's.
There is actually quite a bit more clearance than even an unmilled stock valved head.
But regardless it's mating up to a shortblock with the correct flycuts for 11* ET heads.
The issue is the ET 215 is a awesome heads and flows great numbers
The T-Rex cam was decided for max effort with the lower flowing of the stock head, but the valve events on the T-Rex are great and has great lobes (XER).
Ideally, maybe a slightly small duration cam would be better. I am not sure what the valve event are on the 233/239 cam are or what type of lobes.
I would call Geoff @ Thunder Racing he can answer your question best.
If I had two chose between the two, hands down T-Rex
ET 215 and T-Rex will get the job none!
Is it the best combo?
Bob
Bob
Bob
would someone mind elaborating on how the cam is designed for heads with low flow numbers? and how would anything in that case not work just completely better with higher flowing heads...just a little confused about that.
thanks
Louie
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Of the two I have the 233/239 comes up with a DCR of 8.6x and the TRex a 8.4x I am almost inclined to try the 233/239 with the higher DCR. But then again the TRex has been 'proven' on the ET215s at 58cc.... hrmmmm
plan on revving to the moon if you put the trex in @ 108-110 ICL with the vic.
