Factory Engine Oil Cooler ???
Old May 8, 2006 | 10:17 PM
GONEB4U's Avatar
Default Factory Engine Oil Cooler ???
I noticed on my F-Body road race car that it has a GM engine oil cooler. To the best of my knowledge; I don't think that they ever came with a remote mounted engine oil cooler. Does anyone know what GM car or truck came with an aluminum block with to hard ( screwed to engine right above the oil filter) 2- 1/2 inch aluminum lines coming out of the block going to 2 rubber lines(around 30 inches) with 8 an fittings on both ends? I crimped one of the hard lines taking out my drivers header and would like to replace it with the same setup. Thanks in advance.
Old May 8, 2006 | 10:31 PM
Quik's Avatar
my LQ9 has two lines coming from above the oil filter to the rad for an oil cooler
Old May 8, 2006 | 10:33 PM
GONEB4U's Avatar
I assume it is a 03 or newer Escalade or SS Silverado.
Old May 8, 2006 | 11:06 PM
Quik's Avatar
the motor is from an 03SSS but now installed in a 02 silverado with the same rad setup
Old May 9, 2006 | 08:18 AM
GONEB4U's Avatar
Thanks.
Old May 9, 2006 | 08:50 AM
joelvette's Avatar
i got an lq9 from a 2002 escalade that had that setup.
Old Jan 19, 2007 | 12:10 PM
Sandemonium's Avatar
Do you know if a block off plate is available to delete the oil cooler? My application will not be needing an Oil Cooler.
Thank you in advance for the reply's
Old Jan 19, 2007 | 01:02 PM
STRIPSTAR's Avatar
This is the only one I know of.
http://www.w2wpowertrain.com/pc-53-3...k-for-ls1.aspx
Old Jan 19, 2007 | 02:47 PM
12secSS's Avatar
All LQ4/9 trucks had that (or at least with the tow package). My 2002 1500HD has that OEM oil cooler. you can replace that with a passenger car version and vice versa. I do not know the techinical term for it, but the dealer should have them available.
Old Jan 19, 2007 | 03:54 PM
Smile
Great, Thank you for the reply.....
I will check with the dealer on this item.
Old Jan 19, 2007 | 03:55 PM
GR33N GoblinM6's Avatar
Katech makes one... so does Lingenfelter..
I used a sandwhich adapter on mine..
Old Jan 20, 2007 | 09:33 AM
GONEB4U's Avatar
Just run the factory block off of a F-Body. That is already plugged.
