is this normal???
Old May 9, 2006 | 03:46 PM
01arroyo's Avatar
Default is this normal???
I have a 01 trans am with hooker long tubes, ory, k&n intake. well the problem is when i try to smoke my tires my rpm dont go over 2000, but when i take off rpms go up like normal. is this normal??? i dont have traction control on my car
Old May 9, 2006 | 03:47 PM
Orange Peel's Avatar
Not normal. Is it a A4 or M6? Are you using the brake to burnout? Definitely seems wrong, anything done to the PCM yet?
Old May 9, 2006 | 03:52 PM
seth webster's Avatar
damn thats crazy
are you absolutley sure you dont have a ASR button?
Old May 9, 2006 | 03:55 PM
01arroyo's Avatar
its an auto. i use the brake to burn out. it only does this on certain streets. could it be the street??? my brothers mustang burns out nice on the streets i cant. he said that his car did the same and that he changed plugs and that worked could it be that????? i didnt have anything done to the pcm
Old May 9, 2006 | 05:03 PM
Bill'sWS6's Avatar
If the car is warm/hot and the the street you are on is hot you may have a hard time with the stock converter. I did that last year. Took my friend out for a ride and was playing around. I got the car real warm and pulled onto a side street. It was an 80 degree day and the tires were hot, street was hot and car was hot. I couldn't get the tires to turn over, stuck hard to the street.
Best thing to do would be try that when your car is cold in the morning. If it still acts that way when cool you may have a tranny issue. If it works okay you may have just had the same problem I did. My car went out and ran in the low 12s a couple days later.
Good Luck!
Old May 9, 2006 | 06:01 PM
SuperC1's Avatar
If you are trying to burnout while holding the brakes it will be hard. If your car has abs then brake pressure is being applied to all four tires.
You should purchase a line lock to hold the front tires only and then you can light the back tires up at will.
Old May 9, 2006 | 07:04 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You sound like you need a line lock.
BTW: How does this have anything to do with Internal Engine?
Old May 9, 2006 | 09:10 PM
what kind of tires do you have on the car??
mickey tompson ET streets might make it hard to do a nice burnout on the street
Old May 10, 2006 | 01:25 PM
01arroyo's Avatar
i didnt know what it had to do with so i just posted it
Old May 10, 2006 | 01:26 PM
01arroyo's Avatar
im running regular street tires. it only does this on certain streets though. i can burn it beautiful on some streets even with the brake applied.
