New cam, but problems
I'd pull it apart and check the oil pump and also put some titanium pushrods in there. You might want to invest in a pushrod length checker - $20(?).
Good luck
You don't need better pushrods but i would recomend some 7.425 chromoly pushrods to quiet down the valve train.
You ticking problem was answered in the foirst reply "shouldaboughttheZz".
You need to put a NEW o ring in there. with the heat the oring will shrink and there fore you CAN NOT re use it. i have installed over 100 cams and have seen this a few times. people bring me cars that are ticking and have lower oil presser after doing a cam/ oil pump swap. and every time it has been that they reused the o ring. well actually once it was pinched.
take it back out. take the oil pump apart and install just the oil pump case first with a new o ring. after you get the oil tube bolted up you can reassemble the oil pump and put everything back together.
I do it this wayu cause it is easier to put the oil pump on AND you can see the pick up tube outlet after you bolt it on so you can't pinch the o ring.
and then tell me I'm wrong - I do this for a living.
From the site you posted:
F
I would'nt let you work on my weedwacker.
BUt chromemoly hardened pushrods of the proper length will work nice and might quiet things down. Plus they are much cheaper than titanium!
...and the oil "thickness" deal. Anyone that has done an oil change would know that the oil drains much faster when the engine is warm, 'cuz it's thinner.
But what do I know Im Fuggin crazy
guess i'm gonna try putting a new o-ring in today.... and that's the spring kit that came in the cam kit
i dont really understand how that's gonna stop the ticking from the lifters... but ... i'll give it a try, and hope for luck!
