New cam, but problems
Old May 11, 2006 | 10:22 AM
  #41
StreetnStrip's Avatar
Closed ex-Sponsor Account
[quik]------------------- you may have bearing issues if you never did have good psi and now with a ported pump still having low psi. then i would worry about your motor. and honestly you have to much spring pressure for that cam. another reason why i dont like that company you delt with. with that cam of yours you should of just ran 918s.
replace lifters, change springs to 918s and hopefully then your issues are gone but really i do believe if you never seen your oil psi peg under WOT then you have motor issues
Old May 11, 2006 | 10:44 AM
  #42
SonofaBish's Avatar
ehh... honestly i never paid attention to the oil pressure at WOT...
i just konw that at warm idle it was in the 40 range... and under normal driving it would increase to the next line i think (dont recall off the top of my head what that temp is) - and i really don't have the $$ to go buying another set of springs, etc.
When i bought it, the company said they had a very large amount of ppl with the same setup as mine and were very happy with the results... so i dont see why they would sell this as a set, if the sprigns were too strong for the cam...
but who knows
Old May 11, 2006 | 10:46 AM
  #43
shouldaboughttheZ's Avatar
Originally Posted by PREDATOR-Z
Mine is blue
Blue, I have never seen one blue.
  #44
Y2K Z28's Avatar
Originally Posted by 01Bird_of_Prey
Oil is it's thinnest when it's cold and it's thickest when it's warm, so there goes that theory
Oil is thickest when cold then as it gets hotter it thins but at the point of overheating it breaks down and turns to sticky sludge.
Old May 11, 2006 | 10:56 AM
  #45
but who knows
im smacking you in person. that company is garbage IMHO, they sell things that fail. do a search and see how many ppl been having issues with them. and 918s are only like 160, sell those you have and buy the 918s.
Old May 11, 2006 | 10:57 AM
  #46
PREDATOR-Z's Avatar
Blue-green ??
At least this is the way I see it
Old May 11, 2006 | 11:27 AM
  #47
Gunnar@Patriot's Avatar
The Patriot Gold springs work well with this cam. We have several hundred guys using them and have 0 issues.
Old May 11, 2006 | 12:29 PM
  #48
Z'mnypit's Avatar
Originally Posted by StreetnStrip
im smacking you in person. that company is garbage IMHO, they sell things that fail. do a search and see how many ppl been having issues with them. and 918s are only like 160, sell those you have and buy the 918s and we do have a set in stock
What the hell does his ticking have to do with that company? All he did was swap cams/pump/springs. When there is oil pressure issues, after the car warms up, then a tick, and to top off they didnt use a new o-ring. Now where do you think the problems is? O-ring maybe, or possibly his mechanic. Afterall the first time he did leave the o-ring off. My advise, take it to some one that know's LS1's. Also- so if he sells his gold springs & buy's the 918's the ticking is going to disapear right? Dont think so!
Every o-ring that Ive swapped has been blue, never seen a green or black one.
Have you checked all the rockers? Ive seen them tick after warming up if they are loose.
Old May 11, 2006 | 12:34 PM
  #49
dude hush up, im not comparing his ticking to the springs for that company. i did say the springs are overkill for his setup. read closer!!!
his motor has more issues then he realizes. have you heard his motor? NO you didnt, have I? yes i have. before the cam swap it made all kinds of abnormal noises.
Old May 11, 2006 | 12:52 PM
  #50
Z'mnypit's Avatar
Still have to disagree, I dont see them being overkill. Why would they be included with the cam if they were to much? If his engine made all kinds of noises before the cam, why not fix that stuff first instead of trying to make it sound like its patriots fault. No saying you made it out that way but thats where this thread is going. He needs to mention that he had problems before even starting the swap.
Might want to cut the oil filter open to see what you find, he may have some bearing issues. (been there done that.)
Old May 11, 2006 | 01:10 PM
  #51
i said that somewhere he might have bearing issues.
ive read and seen to many issues with patriot parts failing. and as for what they offered i personally would of never went with his setup.
Old May 11, 2006 | 01:28 PM
  #52
Z'mnypit's Avatar
In the past, I would agree with you. But they have come a long ways since then. If you do see any failures lately they are either from old parts, or its something that generates failure. Im on here everyday & I havent seen all these failures you keep refering to.
Old May 11, 2006 | 01:42 PM
  #53
SonofaBish's Avatar
ok... wait a min... don't start making it seem like i'm blaming patriot...
the engine made some excess valvetrain noise before.... but nothing like what its doing now.... and i mean NOTHING like it is now... and i dont feet that it is patriots fault... it seems pretty apparent that the lifters are collapsing.. sooooooo...... we're trying the o-ring idea.... i'm just praying it works... if it doesnt... i dunno where to go... yea, i can replace lifters, but then that won't fix the fact that oil pressure is still a lower than it should be....
and anoterh question - not being smart, cuz i really dont know - how would bearing issues cause what is happening?
Old May 11, 2006 | 01:43 PM
  #54
alot of the failures have been from older parts. somthings in the last 2yrs or so
Old May 11, 2006 | 01:49 PM
  #55
Z'mnypit's Avatar
Like I mentioned earlier, with the oil pressure being low & there being a ticking noise. Im pretty sure you problem is the O-ring. You re-used the stock one right?
Old May 11, 2006 | 01:52 PM
  #56
98Z28MASS's Avatar
lol the springs you have are fine, dont switch to 918's...although they would have been fine I dont think they are causing your problem whatsoever. Swap the pushrods if you want, but def check out the o-ring on your oil pump. Then maybe check to see if you collapsed a lifter. Just take your time and dont run the engine long if the oil pressure isnt up to par, otherwise you will need a new engine. Good luck though and keep us updated.
Old May 11, 2006 | 02:01 PM
  #57
SonofaBish's Avatar
that is correct, sir.... when we installed the oil pump the first time, we didnt realize that the new one didnt come with an o-ring... so when we were stumped, we looked at the old oil pump, and saw a ring on it... and wondered... so we tore it down and found it w/o an o-ring... so... we re-used the old o-ring... i'm currently without a vehicle with a roof (all i have is my sportbike) so since it's pouring down rain right now, my buddy/mechanic is working on it as we speak....
i'm hoping
Old May 11, 2006 | 02:11 PM
  #58
i'm hoping
Keep us posted on how everything turns out.
Old May 11, 2006 | 02:12 PM
  #59
Z'mnypit's Avatar
i'm hoping
Sucks! Yeah dont reuse the stockers. Most of the time they will tear. Also make sure the new one doesnt get the slightest pinched. May have to get a mirror to see behind it. The new ones dont look like the old stock ones & are somewhat of a pain to get in correctly. Just lube it up with some oil and carefully slid it in. May take some working with. Good luck!
Old May 11, 2006 | 02:14 PM
  #60
98Z28MASS's Avatar
i'm hoping
Yea I hear ya. I had a similar problem with my buddies 02 z28 after a cam install. We pinched the o-ring and it wasnt getting enough oil pressure. Switching to 918 springs would be taking a step back, and although 918's work well the dual valve springs are just extra insurance against a valve spring braking, but it def wouldnt hurt your setup whatsoever. I hope thats your problem as its a pretty easy fix, just make sure its getting enough oil pressure or kill the engine quick as you can cause some serious damage. I hope everything works out and goodluck.
