New cam, but problems
Old May 10, 2006 | 08:33 AM
SonofaBish's Avatar
Default New cam, but problems
My buddy and I just installed the cam into my LS1 T/A... specs are 232/230 .580/.580 110LSA... the first problem we ran into the other day was that when it started, it sounds bad-***, and ran fine, but then once it was completely warmed up, it started ticking really hard from the valvetrain and the oil pressure suddenly dropped really bad... Well, as we looked around, he saw that he forgot to put the little o-ring from the old oil-pump into the new ported LS6 oil pump. Ok, so whew! problem averted there!...
But now the next, current problem... The car now keeps decent oil pressure, around 30 at warm idle, but once everythign is warmed up for a few mins, the hard ticking comes back... It runs/sounds awesome the whole way warming up, and for the first few mintues that its at full temperature. But then, like i said - it starts that really loud ticking again. My buddy said its b/c the lifters are collapsing for some reason. He's thinkin maybe the springs i put in (dual springs good for up to .650 lift) might be too strong for the lifters, and are bleeding them out once the oil gets really hot and thinned out....
So, today he is going to try a higher weight oil to see if that will help it out (20W50 i think is what he's gonna try - I heard of ppl doing this with this engine) ... but, are there any other thoughts on this? Anythign i can do? would new lifters be stronger, and make this quit?
i just need a little help/suggestions. Thanks!
Old May 10, 2006 | 10:41 AM
SonofaBish's Avatar
no ideas?
Old May 10, 2006 | 11:26 AM
shouldaboughttheZ's Avatar
Why are you re using the o-ring on the new pump. Did it not, come with a new one?
This is not decent oil pressure. a stock ls1 oil pump should put out between 40-45psi at idle and around 60psi driving and WOT.
I would replace that o-ring with a new one. Putting the old one back in, you could have not put it in right and that would explain the low oil pressure.
After you replace the o-ring, try letting it warm up again. If the ticking persists then you might have a bad lifter.
Old May 10, 2006 | 11:32 AM
PREDATOR-Z's Avatar
What size pushrod did you use?
Is it a Comp Cam?
And yeah, definately take a look at the O ring again. Put a new one in and make sure you do not pinch it.
Old May 10, 2006 | 12:00 PM
SonofaBish's Avatar
i used the stock pushrods....
it is a Patriot cam, but is still a comp cam i believe...
i will have him check out the o-ring agani, but that means a lot of tear down AGAIN... its just that little rubber ring that goes where the oil pump connects to w/e hooks into it from underneath... (i'm guessing coming from the oil filter or something)... how could you pinch it... it just plops right into there... and NO, it didn't come with that ring...
Old May 10, 2006 | 12:03 PM
SonofaBish's Avatar
and... am i not correct in the assumption that oil pressure is a relative term.... b/w flow and resistance... so if its flowing well, but maybe there isn't as good of resistance (thus lower pressure), that doesnt mean that there's not enough oil getting to the parts....
am i right?
Old May 10, 2006 | 12:12 PM
ShevrolayZ28's Avatar
Duel springs and stock pushrods is a bad, bad combo. The stock pushrods will bend under that kind of spring pressure. Not to mention that you may also benifit from a slightly longer pushrods, if I'm not mistaken.
I'd pull it apart and check the oil pump and also put some chromemoly hardened pushrods in there. You might want to invest in a pushrod length checker - $20(?).
Good luck
PREDATOR-Z's Avatar
I bet my Lifesavers that you bent your p-rods.
You need hardened pushrods with the seat pressures on those springs.
Dissasemble, and put 7.425 p-rods. Comp cams.
Do not use 20W50 with the LS1. It does't like that.
Use either 0W40 or similar.
Change the O-ring.
Old May 10, 2006 | 12:13 PM
While you are in there, if it is not already equipt, you may want to install an LS6 oil pump.
Old May 10, 2006 | 12:15 PM
'02 SLP#686's Avatar
Stock pushrods
Old May 10, 2006 | 12:16 PM
SonofaBish's Avatar
ok... thanks for the help guys, i really appreciate it, but why woudl it wait until it got hot to start ticking? wouldnt bent pushrods just tick hard all the time?
Old May 10, 2006 | 12:17 PM
SonofaBish's Avatar
yea, i put a ported ls6 pump in it
Old May 10, 2006 | 12:24 PM
That's a good question but I don't think anyone will disagree that you need to install better pushrods. If they aren't bent already, they may bend soon after you get on it s few times.
Old May 10, 2006 | 12:42 PM
stealth71's Avatar
Yeah bent pushrods will tick for sure
Old May 10, 2006 | 01:01 PM
s346k's Avatar
..but wouldn't bent pushrods tick ALL of the time and not just when the oil got warm?
Old May 10, 2006 | 06:43 PM
SonofaBish's Avatar
any more thoughts?? my buddy ran it, let it cool down, ran it, let it cool down, ran it... all day long... not a problem
then i got there tonite and ran it around a little bit... everythign seemed fine... but then i took it back to his shop... and after it sat for about 30 seconds or 45 it slowly started to come back and tick hard again
Old May 10, 2006 | 06:59 PM
MattIROC's Avatar
change the pushrods as everyone else said. that will fix your ticking problem.
Old May 10, 2006 | 07:37 PM
SonofaBish's Avatar
i don't understand... HOW? if the damn thing doesn't tick when its cold... or even half the time when its warm, then how does that imply that there is a bent pushrod??
i'm not getting an attitude, i'm just trying to understand this... i dont see how that is possible...
Old May 10, 2006 | 08:16 PM
01Bird_of_Prey's Avatar
So, today he is going to try a higher weight oil to see if that will help it out (20W50 i think is what he's gonna try -!
Oil is it's thinnest when it's cold and it's thickest when it's warm, so there goes that theory
Old May 10, 2006 | 08:22 PM
SUX2BU's Avatar
wrong.
