Will Torquer 2 fit w/ heads milled .015?
I just bolted my heads on and am about to buy a new cam (again). I want to keep the duration in the low 230s and the lift around .600 due to using 918s. The Torquer 2 seems like a good choice but my heads are milled .015 so I know it will be tight. I was thinking a 112 LSA and 110 ICL would suit me best. I don't want to retard it anymore or go higher on the LSA. So since I'm not going to notch the pistons, will the T2 work?
It also depends on what size valves you have and the LSA/ICL of the cam
I had a 113+0 on 2.04/1.575 milled .010 with stock gasket.
Talk to TSP they will tell you for sure.
