PTV clearance question...
Old May 14, 2006 | 08:12 PM
SSpdDmon's Avatar
Default PTV clearance question...
Didn't know if anyone on here has some good knowledge about PTV on an LS1. Friend of mine has a '99 and just bought a TSP Torquer cam (232/234 .595/.598 112LSA) along with a set of Stage 2 LS6 heads milled slightly so that they have 63cc chambers. He's been running a set of Comp Cams Pro-Magnum 1.75 rocker arms. If he transfers those rockers to the new heads, his new cam specs will be more like 232/234 .613/.616. Does anyone know if he'll be able to run those rockers with his new setup or will he have to go back to a 1.7 ratio?
Old May 14, 2006 | 08:16 PM
ThirdGenLS1's Avatar
lift has little to do with PTV, its mostly about valve events and duration. His best bet is to just get a checker spring, dial indicator, and measure it him self.
Justin
Old May 14, 2006 | 08:19 PM
brad8266's Avatar
Justin
PTV issues are more coorelated to cam duration with lift combined. You could have .6 lift with no issue as long as this lift occurs when the piston is at the bottom of the bore, but if it has .5 lift when the piston is almost at top it could crash. Duration will determine the valve events.
Old May 14, 2006 | 10:02 PM
SSpdDmon's Avatar
Ok...so maybe I asked the question wrong. But, that still has nothing to do with whether or not the setup will work. Does anyone know if this setup will work with 1.75 rockers without having to go through the whole buying new tools or puddy to check clearance? If not, that's fine....but don't sit there and belittle someone for making a small mistake in his question.
Old May 14, 2006 | 10:04 PM
the thing is i dont think anyone is going to be able to give you a 100% answere on this. It wil be tight, as to how tight you wont know unless you check it.
Old May 14, 2006 | 10:31 PM
brad8266's Avatar
Nobody belittled you man, what made you think that? We just told you how it is.
Old May 15, 2006 | 01:52 AM
Quik's Avatar
tv2 112 243 castings on a LQ9 which has flat top pistons, 6.0 MLS gasket and no PTV issues. motor runs fine
hopefully that gives an idea
Old May 15, 2006 | 04:44 AM
PREDATOR-Z's Avatar
If you run stock gasket, you should be fine. Just make sure that you preload the lifters right.
And checking should be mandatory.
Old May 16, 2006 | 08:40 PM
JS99Z's Avatar
I was told since I have the comp r lifters if I want to go back to 1.7 ratio I can't use the stock rockers, they have to be adjustable rockers. Is this true?
By the way this is my never ending project SSpdDmon's
talking about in this post.
Old Jun 16, 2006 | 03:10 PM
ls1z01's Avatar
How thick is the stock head gasket?
Old Jun 16, 2006 | 04:36 PM
Xtnct00WS6's Avatar
I've seen different numbers ranging from 55 thousands to 60 thousands
Old Jun 16, 2006 | 04:42 PM
mine was 55 when i measusred it
