H/C swap with problem. Coolant in exhaust...NEED HELP!!
Old May 23, 2006 | 08:34 AM
8GTOKLR's Avatar
What did you send and what was the issue?
Old May 23, 2006 | 03:32 PM
marv's Avatar
Originally Posted by LS1-450
Glad to hear you found the problem & that TSP responded quickly & accordingly. For sure a sign of a good company. Let us know when she's done.
Yeah man, the TSP guys have been more than good to me. Can't say enough good things about them. Talked to Jason and a few others multiple times and they all were very helpful.
I'm sure I'll be doing business with them again in the future!
The new head will be here tomorrow and I hope to have it in and running by tomorrow evening. I'll post up and let you know how it goes.
Old May 23, 2006 | 03:35 PM
marv's Avatar
One of my LS6 CNC'ed heads had holes in the water jackets in the intake runners on three cylinders. Probably had a machine get out of spec or a bad tool got into it. Long story short, I had water in #4,6 & 8.
Called them up on Monday, told them the problem. Jason (owner at TSP) told me what he needed off the old one and is overnighting me a new one tonight.
Good folks to deal with.
8GTOKLR's Avatar
so it was a bad head and not the gasket. sorry to hear yet im glad you got that under wraps
Old May 23, 2006 | 03:38 PM
marv's Avatar
Yeah at first I thought it might be the gasket, but when I thought about the amount of water it went through, I figured it had to be something else.
Gasket was still in good shape, wasn't really even stuck to the block. But it wasn't even on there for 48 hours. It'll get replaced with a new one though.
I'll be glad to get that thing together and off the ramps. It's been over a week since I drove it and I'm having withdrawals!!
But I have been saving on gas!
Old May 23, 2006 | 07:55 PM
BAM-BAM's Avatar
they do have good customer service and have taken care of me as well
i just sent back a set with the same problem...ported through on the intake runner....i talked to jason on this as well...jason if ya read this they will be there on thursday the 25th...according to ups...
Old May 24, 2006 | 08:40 AM
marv's Avatar
So did you experience this same problem on a set of the CNC'ed LS6 heads, or was it something else?
Old May 24, 2006 | 09:33 AM
BAM-BAM's Avatar
it was the cnc ls6 heads with the 2.04 /1.57 valves...you could see and feel in the intake port where the hole(crack) was....not to mention the clean valves in that cylinder that showed it was burning coolant...mine was just in one cyl...
Old May 24, 2006 | 12:59 PM
perdieu's Avatar
WOW looks like I'm not the olny one thats had this problem..here are a couple pic's Jason took care of sending me a new head. I was just out the double install money
Attached Thumbnails H/C swap with problem.  Coolant in exhaust...NEED HELP!!-motor-033.jpg   H/C swap with problem.  Coolant in exhaust...NEED HELP!!-motor-034.jpg
Old May 25, 2006 | 08:42 AM
marv's Avatar
Nah man, you're not the only one...
But on another note...
IT'S ALIVE AND RUNNING!!!!
Got it back together last night...she fired right up...still got a few bugs in it, needs an O2 sensor on the drivers front bank, but other than that...everything seems okay.
I looked all over the head that I had that was cracked, but couldn't find a thing. Friend of mine came over last night to wrap up the final details of the install and immediately noticed the crack.
Looked on the floor of the intake runner and there was a crack...he pressed on it and his finger went right through the runner!!
I couldn't believe it. Never seen that happen before. Two of them had cracks you could see....and a third was soft enough in that spot that you could have pushed it through.
But, bottom line is that TSP stepped up to the plate and remedied the situation ASAP. Can't say enough about the company or the people that work there. Thanks again guys!
Old May 25, 2006 | 05:23 PM
Xtnct00WS6's Avatar
Wow! I really wish there was a way for the "Do-it-yourself'r" to know the thickness of those kinds of areas.
Old May 25, 2006 | 09:49 PM
  #32
72ChevelleConv.LS1's Avatar
Another thing to watch out for is the castings used for the Al parts some time will have porosity in the parts. some times after porting the head, this will be exposed to the coolent jacket. they can then leek too.
