Resleeve just one cylinder?
If you sleeve a cylinder stress honing the rest of the cylinders for larger pistons may be needed. Re-sleeving will most likely distort adjacent cylinders.
very true, but "done right" is a really big if...at least from my past experiences.
You can indeed fix a block with a scored factory liner using the above sleeve. I have repaired more than one block using these sleeves. The aluminum behind the cast in sleeve must be intact. If the aluminum is cracked there is no sure fix other than installing MID sleeves - more than you want to spend.
You can have your local shop give me a call. I'll be happy to tell them how to install that repair sleeve so you end up with a usable piece. It would be too expensive to ship to Ca. to repair one cyl.
Steve
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
