smoke
Old May 24, 2006 | 07:00 PM
1sickta's Avatar
Default smoke
alot of smoke coming out of my tail pipe after install head, specialist when push gas pedal little bit why is that ?
Old May 24, 2006 | 07:19 PM
vettenuts's Avatar
Immediately after install or when you drive the car? There will be some smoke from the engine compartment and tailpipe immediately after you start.
Old May 24, 2006 | 07:22 PM
andypdbz's Avatar
that hurt to read...
Old May 24, 2006 | 07:28 PM
1sickta's Avatar
when i drive my car
Old May 24, 2006 | 07:29 PM
1sickta's Avatar
sorry i'm not that good of english.i'm ESL
Old May 25, 2006 | 08:51 AM
GuitsBoy's Avatar
Is the car tuned? Are the valve seals on the heads new and installed properly?
Old May 25, 2006 | 10:12 AM
LsReddog's Avatar
Are the heads CNC ported? If so than check to make sure your intake rocker bolts are sealed properly.
Old May 25, 2006 | 11:27 AM
Bad30th's Avatar
I'm betting head gasket(s) or bolts incorrect torque order/spec ?
Rob (Bad30th)
Old May 25, 2006 | 02:13 PM
1sickta's Avatar
car is not tune yet and DLA the one instal it. some say valve guide because it smoke is smell oil.
1sickta's Avatar
Originally Posted by LsReddog
Are the heads CNC ported? If so than check to make sure your intake rocker stud bolts are sealed properly.
yes its ported.
Old May 25, 2006 | 02:14 PM
1sickta's Avatar
Rob (Bad30th)
i hoping you are right because i don't want to buy another head and go through hassle again.
Old May 25, 2006 | 02:21 PM
vettenuts's Avatar
yes its ported.
Did you seal the intake bolts for the inake rockers?
Old May 25, 2006 | 03:11 PM
1sickta's Avatar
Don Lee install it for me and i will take it back to them on wed. hope fully the head is good so i don't have call TSP.
Old May 25, 2006 | 03:26 PM
Bad30th's Avatar
If Don Lee Auto did the install I would be confident it wasn't a problem with the install (I mean anything is possible but they do awesome work).
There has been a recent batch of TSP ported heads that have had reports of smoking due to some porting issues... Look around in this forum for other posts on TSP/Dart smoking issues. If it turns out to be the heads I'm confident TSP will get things squared away for you.
Rob (Bad30th)
Old May 25, 2006 | 10:37 PM
SlickVert's Avatar
99% it is only the intake rocker bolts were not sealed.
Easy fix.
Bob
Old May 25, 2006 | 11:19 PM
1sickta's Avatar
Easy fix.
Bob
how to open and look for the intake rocker bolts ?
btw i opened valve cover and i saw mount of oil there is that normal ?
