Ls1 Hot cam #'s
Old 05-28-2006, 12:15 PM
barracuda_440's Avatar
Default Ls1 Hot cam #'s
Hey guys, just wondering what people are putting down with full bolt ons and hot cam, Lemme know, track times? i could be picking one up really cheap. Can i use my stock valve springs?
Old 05-28-2006, 12:30 PM
Bo White's Avatar
I wouldnt use stock springs with the stock cam. That is one of the first things I did to my car- valve spring replacement(I went with the yellow springs). A buddy of mine had a TA M6 and put down 365rwhp with the stock heads and this is an average # that Ive seen on the board- some a little higher, some lower.
Old 05-28-2006, 12:53 PM
hmm im sure it would do alittle better with some different rocker arms too right?
Old 05-28-2006, 02:13 PM
blkbird's Avatar
Im about to dyno mine this coming week. I will post up what numbers I get.....
Old 05-28-2006, 02:59 PM
2000TransAmWS6's Avatar
375hp/378tq
with longtubes, texas speed rumbler, lid, Ls6 intake manifold, LS1edit tune.
i have been unable to get a good run down the track because my clutch was giving up.
you're going to have to put new springs in with that cam. you can pick up some LS6 springs for fairly cheap.
Old 05-28-2006, 03:25 PM
SVC707's Avatar
i put down 380ish with flowmaster and cutout open, stock rocker arms, but the basic bolt on
Old 05-28-2006, 10:09 PM
jbuckweiser's Avatar
I got 411hp/383tq with 1.8rr's and heads. It's been retuned and had more mods like
W/I and 30# SVO's. Waiting to redyno, but has alot more PULL from original dyno run.
Old 05-29-2006, 08:49 AM
'99slobird's Avatar
I got 400/405 on my 383 with true duals, long tubes, ported heads, and 1.8 rockers through an A4 (with a very flat curve). If you are going to run 1.8's, I'd go with a better spring. The LS6 is rated to .550 and with 1.8's your lift should be @ .556 (if I figured it right). If you get some stronger springs, you'll be covered if you want to go to a bigger cam later on, too.
Old 05-29-2006, 11:32 PM
moeZ28's Avatar
In my 1998 A4 with 120k miles, headers, cutouts, stock LS1 intake, I made 365hp and 362lbft. A friend of mine made 375hp and 374 lbft in his 2002 m6 with headers. I will always say the hotcam is a good camshaft.
Old 05-30-2006, 01:07 AM
RooRnZ28's Avatar
i still have yet to get a tune...but it pulls a lot harder than stock. i'm hoping for some good results after it gets dyno'ed!
Old 06-01-2006, 06:55 PM
blkbird's Avatar
Got it tuned today and put down 375rwhp and 362rwtq..... Really got to get rid of the crapmaster.......
Old 06-01-2006, 08:26 PM
here are the mods im gonna have
Jet hot longtubes, Ls6 intake, ported tb, SLP lid/filter, tuned, TSP duals, and MAYBE ported stock heads? but those numbers arent bad guys, thanks alot.
Old 06-01-2006, 09:57 PM
yeah, getting rid of it would help... i gained 32 rwhp by swapping my Flowmaster out for a TSP Rumbler and removing the little JetHot cats from my headers.
Old 06-02-2006, 11:08 AM
meatfoam's Avatar
My numbers with hotcam and bolt ons are 374hp / 358 lb/ft.
I ran a best of 12.4 @ 115.5 in the 1/4 on street tires.
Old 06-02-2006, 04:13 PM
Temple, TX Resident
SiRgReg23's Avatar
i put down only 318 on a mustang dyno with my mods and hot cam kit .... i think i really need a tune or something is wrong with my car
Old 06-02-2006, 04:29 PM
Cali SS's Avatar
I put down 374/371 with Jet Hot LT's, ORY, Lid, Hooker cat back, and a dyno tune.
The best time I've got so far was a 12.7@115 mph 2.1 60 foot.
Old 06-03-2006, 10:08 PM
LS1BlackBird99's Avatar
How is the lope sound for this cam? What are the difference in specs between this cam and the stock cam?
Old 06-04-2006, 08:13 AM
1baddls1's Avatar
198.86 intake 209.25 exhaust
lift .498 intake .497 exhaust
LSA 119.45
1baddls1's Avatar
196.37 intake 208.72 exhaust
lift .464 intake .479 exhaust
LSA 115.92
Old 06-04-2006, 08:14 AM
1baddls1's Avatar
Hot Cam
218/227 .525/.525 112 Lsa
def a good choice for a good mild cam, i personally love the TR 224/224 112LSA
Quick Reply: Ls1 Hot cam #'s
