reliability
I am sure there will be plenty of theories. I'd like to know the answer to that question also.
Also, I think you're going to need more than 5 psi to make 500 rwhp on a bone stock LS1. I could be wrong though. Also, 500 rwhp from a Procharger will not be as a fast as 500 rwhp from a H/C package since the boost pressure from a Procharger increases exponentially to redline meaning that if you pulley the SC to make 6 psi at 6k RPM you will only make around 1 psi at 3k RPM.
I think making 500 rwhp from a H/C package is just too unrealistic so I really can't answer the question.
Made 473 rwhp and 431 rwhp using the G5X3 and FAST 78 mm with a ported throttle body.
But you are right, that would've been more aggressive then I'd have liked. I was shooting for 480 rwhp and 435 rwtq. I should get it with a little more tuning and a quick K&N filter clean and reoil.
My car with the bigger cam, intake and T/b would've made around 510 rwhp 450 rwtq maybe more.
now under which setup do you think the bottom end will last longer?
you're going to have to flycut with that g5x4 cam on milled AFR 205s, and that drop the compression a lil.....
