View Poll Results: WHICH CAM?
MTI X1-230/227
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
26
10.57%
Comp Cams...dono which
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
41
16.67%
TSP-228/228
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
84
34.15%
OTHER..
![](https://ls1tech.com/forums/images/polls/bar5-l.gif)
![](https://ls1tech.com/forums/images/polls/bar5.gif)
![](https://ls1tech.com/forums/images/polls/bar5-r.gif)
95
38.62%
Voters: 246. You may not vote on this poll
best cam for the street?
#64
It depends on your driving style and where you want to be @ what rpm. (It depends on if you want to blow everythng away on the highway, or from stop light to stop light.)
Any future mods. are good to know about as well before making a final decision. If I had to do it all over again, I would have put in a 2 piece timing cover. The Vettes require removal of the steering rack just to remove the harmonic damper bolt. It's fun anyway, or we wouldn't do it.
#65
#67
Location: Somewhere Between Mild Insanity and Complete Psychosis
Originally Posted by blkZ28spt
MS3 is my perfect daily driver cam. ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Most people might be better suited by a 233/239 or FM13 sized cam, but then again LS1tech members have been called the "lunatic fringe of LS1 owners" so maybe you would like an MS3 on a daily driver.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
If not, would it be big enough for either the TSP 228R or Comp 224/228 114lsa?
I don't think I would want to go with a Yank ss3600 2.5str. From what I've read, and correct me if I'm wrong, the 2.5 str would be really loose with 2.73 gears???
Sorry to hi-jack...
#69
Originally Posted by who281
well if i get a cam im most likely getting a set of cnc ls6 heads too...and i really want a mean sounding cam soo what's a good choice....?? and i would like to make aorund 400 rwhp or more??
#70
Originally Posted by Rescue Ranger
PP 243's and 224/228 .581/.588 on a 113+0. 409whp SAE w/ cats. 100% daily driveable and tons of power under the curve. I needa TB/90 setup to get her up into the 420s. the graph in my sig was on my other set of heads @59cc, Patriot's S2, but same cam.
#73
http://media.putfile.com/TA-start-up
231/237 .598/.595 112 Texax Speed Cam
you will like this cam...
#74
The 1-7/8 Kooks LT's got me SAE 424.5rwhp on the stock intake (LS6) stock heads and a 228/230 112lsa. Torque was SAE 410.5rwt. Blackwing at the time. Here is where having 36# injectors @ 4bars, (58psi.) to run it at this point is needed, cam only. I replaced the heads recently, and bought the FAST 90 LSX and used the ETC LS2/LS7 90mm throttlebody. The heads are a ported LS6 #243 Stage II polished head, that has been milled down to 62cc. (11.0:1 CR) I brought this setup over to Slowhawk at DEZ and the stock 40K mile clutch, good for at least C-500ft./lbs started to slip during the torque peak @ 4800rpm. So this new SPEC clutch and flywheel had to be installed. Haven't had it dynoed yet, but it made over 440rwhp at 5000rpm on the slipping clutch. Can't wait to find out where we stand.
#77
had a ton of success with the 224/228 from Cartek..
#78
a cam I had before. that wasn't an overall max achiever. was the ASA cam. It made great torque and decent HP accross the board. and it sounded mean as well. one thing I liked is it had a low lift so I wasnt changing springs every 10k miles. I made 390rwhp, with all bolt on's minus the electric water pump.
