best cam for the street?
Through high-flow cats AND with the factory cat-back in place.
With entry-level heads, you should reach your 400 horse.
Direct-Flo Airlid • SLP Smooth Bellows • Bo White Ported Throttle Body
NGK TR55-IX {Iridium} Plugs • SLP Underdrive Pulley • LS2 Chain
180 Thermostat • TSP Ported Oil Pump • Dynatech SuperMAXX Header System
Comp Cams Custom Grind (220/224 .532/.535 114) • Comp Cams 915 Springs and Pushrods • Custom PCM programming
The Comp Cams grind has an easy ramp rate = less strain on the springs.
Very streetable.
231/237 .598/.595 112 Texax Speed Cam
you will like this cam...
Would like more info. on this car.....
Any other mods?
and, all that stuff about not using the stock valve train is'nt just stuff you want to tell whoever makes the cam to recomend the correct stuff! Rockers, push rods, seals, ect. ect!
i have the TSP 228R on my ls2, and i love it. no need to gear up, plenty of power everywhere, dyno graph in my sig.
But they shine on a roll!! OR at the track with MT's
https://ls1tech.com/forums/attachmen...chmentid=79997
