View Poll Results: WHICH CAM?
MTI X1-230/227
26
10.57%
Comp Cams...dono which
41
16.67%
TSP-228/228
84
34.15%
OTHER..
95
38.62%
Voters: 246. You may not vote on this poll
best cam for the street?
Old Jun 3, 2006 | 04:14 PM
who281's Avatar
Default best cam for the street?
what cam would be good for a DD street car...soo im thinkin midrange power and lots of torque because ill never see the track that much mainly just street races?? i was told i would be faster on the street with a 220-232 range??
i was looking at the TSP 235/238 cam and realized it is useless for what i want...am i wrong is it what i want ??
Old Jun 3, 2006 | 04:24 PM
PREDATOR-Z's Avatar
Best all around street cam is in the 224/228 range anything more and you're relinquishing low-midrange for upper rpm power.
You do not need big to make street killer combos, you need the right SCR/DCR motor combo.
BTW DD is a relative terms, some like a eye watering overlap monster and some like nervous high lift Stealth. It up to you and your taste.
To make it easy for you, if you are going cam only, the get a cam that makes a good 8.5 DCR with the stock compression, with that in mind the highest Duration that will achieve that. Then it is just a matter of choosing the lifts you are comfy with (LOBE choice). There is your good street cam. (no sticky tires, super high stall etc...)
Old Jun 3, 2006 | 04:54 PM
General Jack's Avatar
Get something in the 230 range, lift under 0.600. That should provide you with good hp, pretty good midrange and not kill low end. Also, keeping the lift reasonable will prevent having to change springs as often.
I had the same goals and got the MTI X1.
Old Jun 3, 2006 | 05:48 PM
who281's Avatar
well if i get a cam im most likely getting a set of cnc ls6 heads too...and i really want a mean sounding cam soo what's a good choice....?? and i would like to make aorund 400 rwhp or more??
Old Jun 3, 2006 | 06:24 PM
400 rwhp will be easy with heads, even more so if you're a 6 speed. The bigger the duration and tigher the lobe separation, generally, the meaner the cam sounds.
Old Jun 4, 2006 | 11:44 AM
who281's Avatar
ok i think im goin with the X1 cam but what set of heads would be good for it other than MTI's cause they are WAY to expensive
Old Jun 4, 2006 | 12:25 PM
Street Lethal's Avatar
Agreed.
Sometimes, too much emphasis can be placed on a cam's duration for desired power. With a great set of heads... a tame cam, with the right supporting bolt on's, and tune, could see the numbers that most people are looking for on the street (without sacrificing driveability, which is always a plus).
But if you're looking for that lope though, and want to see those horrific stares everytime you pull up at a stoplight, by all means then... go for it!
Old Jun 4, 2006 | 01:13 PM
who281's Avatar
well ive herd an X1 and it sounds badasss maybe not as great as a HUGE cam but still sounds great to me....soo i just need to find a good set of heads....
Old Jun 4, 2006 | 02:30 PM
TTPBilly's Avatar
"horrific" stares? I love when they stare at you like that!!
Old Jun 4, 2006 | 04:06 PM
who281's Avatar
haha ya i would love to get stares like that...but id rather get the performance and ive been told the 220-230 range is best on the street...cant have the best of both i guess
Old Jun 4, 2006 | 06:10 PM
I must admit, I miss those days.
Old Jun 4, 2006 | 06:16 PM
89Formulaws6's Avatar
ok so my friend has a stock ls1, what cam could he put in there for a d/d setup without havening to change say springs and major stuff?
mild setup.
somethign where he won't have to go into custom tuning
Old Jun 4, 2006 | 10:49 PM
I've got the X1 and think it sounds pretty mean. But I don't have much experience with other cams... so I guess its all relative. I'm adding the MTI S2e heads in another couple of weeks and I'm expecting 425 rwhp through the 12 bolt moser, ~ 500 at the crank. And this is my daily driver. Been running the X1 for about 2.5 years now and still love it.
Old Jun 5, 2006 | 04:46 AM
98A4LS1's Avatar
I'm running the 228 0.588 112+1 (XER lobe) and its definitely streetable with a good tune regardless of how you define streetable. Plenty of low-midrange
power. Very noticeable lope.
Old Jun 5, 2006 | 04:58 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
mild setup.
Jack and crap. You don't want to run the stock valvetrain parts with an aftermarket/bigger than stock cam.
Old Jun 5, 2006 | 08:50 AM
Yep, if you change cam, change springs. Stock springs were built for low lift stock cams. Add an aftermarket cam and no springs, and you're running on borrowed time - and not very much of it. Best case scenario, you break one and just replace springs. Worst case, you break one and drop a valve, destroy a piston and spend $$$ rebuilding the bottom end.
Old Jun 5, 2006 | 08:54 AM
RoastEmSS's Avatar
also a tune is almost mandatory with any size cam
Old Jun 5, 2006 | 05:59 PM
bigman's Avatar
228/228 tsp cam. Best of both worlds. You'll get power everywhere and be very streetable.
Old Jun 5, 2006 | 06:01 PM
pdd's Avatar
pdd
Old Jun 5, 2006 | 06:07 PM
chaos's Avatar
comp XE-R 228/228 here and love it!
