View Poll Results: WHICH CAM?
MTI X1-230/227
26
10.57%
Comp Cams...dono which
41
16.67%
TSP-228/228
84
34.15%
OTHER..
95
38.62%
Voters: 246. You may not vote on this poll
best cam for the street?
Old Jun 5, 2006 | 11:03 PM
Stone0fFire's Avatar
goddamn pdd thats the funniest sig pic i have seen
Old Jun 5, 2006 | 11:19 PM
Onyxhawk's Avatar
My vote is the TSP 228R. I am going to get it soon. I hear it is a badass cam
Old Jun 6, 2006 | 02:23 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
He didn't have that put in....
Old Jun 6, 2006 | 02:51 AM
dustin99a4's Avatar
Originally Posted by pdd
226-230
that is the duration i have in my dd and i want to go bigger soon
Old Jun 6, 2006 | 03:07 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Try 244/248 with stock gears.
Old Jun 6, 2006 | 09:17 AM
marlowchris's Avatar
What about the G5X3, I dont hear much talk about that cam anymore. I am thinking about putting it in my DD.
Old Jun 6, 2006 | 07:33 PM
sdbrown84's Avatar
I had a 224/228 ground from Comp with a 114 LSA.
What most say is this is the largest you can go before you begin to give up considerable low-end for the gain in the high end.
Chose this for MPG, sound, and overall power gains. I knew I was going to give up a large amount of power in the upper RPM, but I didn't want to floor it to get to the power.
Old Jun 6, 2006 | 09:23 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I like full-on top end, but hate the fact that the big cams need 4.xx gears to really take up the slack from the crappy low end.
Old Jun 6, 2006 | 10:56 PM
blkZ28spt's Avatar
Originally Posted by who281
haha ya i would love to get stares like that...but id rather get the performance and ive been told the 220-230 range is best on the street...cant have the best of both i guess
Sure you can. With properly matched gears or converter you can go pretty big on the street. If you want lope get a cam that lopes and build the rest of the car to match it. Nothing better than a nasty *** lope on a stock looking street car when you go to the grocery store.
It never gets old, trust me.
I daily drive a 237/242 .602/.609 113 in an auto with a 4k stall converter and it's just right.
Go into the 230's at least.
You can also get lope by messing with the idle speed.
Old Jun 7, 2006 | 12:00 AM
89Formulaws6's Avatar
Originally Posted by EverclearZ
Yep, if you change cam, change springs. Stock springs were built for low lift stock cams. Add an aftermarket cam and no springs, and you're running on borrowed time - and not very much of it. Best case scenario, you break one and just replace springs. Worst case, you break one and drop a valve, destroy a piston and spend $$$ rebuilding the bottom end.
great thanks, this is hard to explain to a person who is very inexperienced in engine building lol
i tried to tell him but i showed him the post.
thanks guys
Old Jun 7, 2006 | 05:03 PM
who281's Avatar
will someone please explain why a big cam isnt good for racing on street....i know it gets all its power up high but i have my foot on the floor the whole time when i race??
Old Jun 7, 2006 | 05:58 PM
  #32
jic's Avatar
jic
Originally Posted by chaos
comp XE-R 228/228 here and love it!
yeah i heard good things about those
Old Jun 7, 2006 | 07:20 PM
  #33
Dom's Avatar
Dom
What gears do you have?
I'd like to run a 3600 stall with my stock 3.23s. My other camaro has 4.10s and 4200stall and I don't need 2 fbodies that can't be driven on the highway. I don't understand the need for big gears when one has a stall.
What's the biggest cam I can run with 3.23s?
Old Jun 7, 2006 | 09:47 PM
  #34
blkZ28spt's Avatar
There really isn't much of a need for big gears when you hve an auto with a converter. I have stock 3.23s.
The size cam you run depends mostly on what you want and how high of a stall speed you go with. For what most of us would consider 'big' you should up to a 3800 or 4,000 stall speed converter. I ran my MS3 on a 3500 for a short time and it really, really likes the 4k stall...the 3500 just wasn't enough.
Old Jun 8, 2006 | 07:04 AM
  #35
Dom's Avatar
Dom
I'm not going with a cam that big. Maybe something between 228 and 232. I'm also not making this car into a full out drag car. Just want the power for the street. I don't care whether I loose a 1/10 by not going with a stall high enough. As long as it feels fast as hell when I punch it.
Old Jun 8, 2006 | 10:42 AM
  #36
WS6 #3392's Avatar
ok i think im goin with the X1 cam but what set of heads would be good for it other than MTI's cause they are WAY to expensive
My vote goes for the X1 cam. Look in my sig for mods and time. Awesome cam for dd and track use.
Old Jun 8, 2006 | 11:54 AM
  #37
CamKing's Avatar
I wouldn't go bigger then this unless you are going to go with a big stall speed.
Duration
@.006" @.050" @.200"
280/286 224/228 141/140
Valve Lift
.569"/.561"
L/C 114
Old Jun 8, 2006 | 11:57 AM
  #38
CRZYPWR's Avatar
Something that wont need a 4000+ stall... with huge gear, that slips way too much. Unless Your M6. If my car was M6 I wouldnt give a ****.
Old Jun 8, 2006 | 12:28 PM
  #39
blkZ28spt's Avatar
If your converter is too small for your cam it will affect the performance on the street every bit as much as it will at the track. Big converters don't just lose their performance because you aren't at the track.
Also, a converter too small for the cam will lose you more than 1/10.
You should be fine in that range with a 3600 stall speed though.
Old Jun 8, 2006 | 12:32 PM
  #40
CRZYPWR's Avatar
Hey BlkZ28spt. You got 4L60 with 4k stall ? Does it slip a lot ?
Cuz I got 4400 2.5 STR and I can just feel the HP going everywhere but my rear wheels...
