best cam for the street?
Cuz I got 4400 2.5 STR and I can just feel the HP going everywhere but my rear wheels...
You do not need big to make street killer combos, you need the right SCR/DCR motor combo.
BTW DD is a relative terms, some like a eye watering overlap monster and some like nervous high lift Stealth. It up to you and your taste.
To make it easy for you, if you are going cam only, the get a cam that makes a good 8.5 DCR with the stock compression, with that in mind the highest Duration that will achieve that. Then it is just a matter of choosing the lifts you are comfy with (LOBE choice). There is your good street cam. (no sticky tires, super high stall etc...)
Mind you this is also relative to the rest of the combo. It is very possible that with the right heads, SCR, DCR the 228 will make more. But that is only true if both combos are optimised for their parameters.
The 228R is XE-R (49 variation ramp rate) while TR224 is (50 variation ramp rate), so the 228 XE-R will make more power.
The VE's will dictate where that power lays.
f10 114-378/372
f13 112-394/366
Im still searching for that cam thats going to give me what i want and an off the market cam isnt going to do it i think.
Most people might be better suited by a 233/239 or FM13 sized cam, but then again LS1tech members have been called the "lunatic fringe of LS1 owners" so maybe you would like an MS3 on a daily driver.
my TS 228R .588/588 is on a 114 and I dont recall what TSP normally grinds into the cam. Its off the shelf.
rest of the combo is
AFR milled -.20 off to 63CC stock GM gasket, ARP head studs. stock gears on MN6, LS6 Manifold, Vararam, plus all the bolt ons.
Current set up is TR224 .563/563 on a 114 and whatever TR grinds into their off the shelf cams, stock LS1 heads, stock gears on MN6, LS6 Manifold, Vararam, plus all the bolt ons.
