Heads up: AFR/Trick Flow/ET heads ** Jesel Rockers...
I pulled my rockers off and found that the center bolts that were supplied with the kit were about .050 too long. I never thought to check the main center bolts that mounts the shafts to the main mount. When we pulled the rockers the bottom of the bolts looked like they had bottomed out on the flat machined pad between the rocker mounting bolts. When we pulled the stand off, the heads had 4 circles where the bolts gouged into the cylinder heads. Pretty much any head that has a single flat area to bolt the rockers will have this problem. When I torqued them down they tightened up normally and looked like the shafts were secure. The bolts need to be shortened about .050
Originally Posted by Grimes
can you put a washer or 2 under the offending bolt?
