Help!!!!!! Oil Leak!!!!
Old Jun 8, 2006 | 10:26 PM
drkbluls1's Avatar
Default Help!!!!!! Oil Leak!!!!
ok so I changed the oil tonight and test drove the car and I was leaving a trail of oil behind me. Had a very small drip of oil before change. and yes I checked the filter and the Plug both tight. It appears to be coming from between the motor and the trans... The rear main was replaced along with the cover about 5k miles ago, could the rear main have gone out again? or is it possible that I over filled it????? Im lost here, it makes no sense that I had no leak before. Also oil is straight 40 so not like it is a thin oil!!!!
Old Jun 8, 2006 | 11:48 PM
Joel_SS's Avatar
If it is dripping from between the motor and trans I would suspect a rear main seal. Could be a cover. Did you or the person isntalling it put sealer where the oil pan and cover meet
Old Jun 9, 2006 | 12:12 AM
staringback05's Avatar
id put money on the gasket seal
Old Jun 9, 2006 | 12:24 AM
jermzz's Avatar
same place mine is leaking, i'm positive its the pan gasket. Prepare for a days work.... lol
Old Jun 9, 2006 | 12:30 AM
drkbluls1's Avatar
yea i know all about the days work, just put the conveter in and everything looked good, damit! Just run it as is, needs an excuse for a big cube motor anyways!
Old Jun 9, 2006 | 12:43 AM
SHINER's Avatar
are u sure its oil? Not brake fluid? Does ur clutch have pressure? Could have "hyperextended" ur slave and it blew...just food for thought..
Old Jun 9, 2006 | 01:05 AM
02 BLK WS6's Avatar
A4 Shiner
Sounds like the rear or pan gasket. Fluid leaks of any kind always suck!!!!!!!
Old Jun 9, 2006 | 01:19 AM
SHINER's Avatar
Originally Posted by 02 BLK WS6
A4 Shiner
haha oops!
Old Jun 16, 2006 | 09:36 PM
jermzz's Avatar
I've done that, too.
shitty.
Smell the fluid, it's easy to tell the difference. If you don't know, then just smell inside your oil cap.
I'm willing to bet the shop didnt put gasket seal between the block and rear of the pan. I just got done changing mine and that was exactly the problem I had. when I put my motor in, I didn't put RTV on the back, just the front. It ruined a new clutch aswell.
Old Jun 16, 2006 | 09:40 PM
SSDoubleK's Avatar
I had the same problem, put some sealant up there and it stopped.
